I'm getting a Panny ax100 and either a 112" or 120" diagonal 2.35 screen. I'm concerned about this 2.0 "throw ratio" that I hear about but don't understand. The panny will be ceiling mounted, 13 to 13.5 feet back about 12 inches above the screen top. From the bottom of the screen to the floor will be about 2 feet (give or take a couple of inches depending on screen size). Was planning on a Panamorph or Prismasonic lens.
Will I be ok ratio wise with either the 112" or the 120"? Or is it back to 16x9 land for me. (I can't move the projector back because of vaulted ceilings....
