Found this site while researching antennas. Worked great for me. Check it out if you need a cheap UHF antenna.
http://uhfhdtvantenna.blogspot.com
Everything You Wanted to Know About HDMI Cables. Ep. 7 of the AVSForum Podcast is now live. Click here for details.
Originally Posted by Rick0725 /forum/post/9647429
mine works better.
going to find better screen and clean it up alittle.
Originally Posted by Falcon_77 /forum/post/11911642
How does your 8-bay build compare with a CM4228? I've been eying the feeder lines on mine between the 2 sides which I've heard causing return loss/radiation problems. As your build appears to have solved that problem, I am curious as to the result.
Originally Posted by seismic744 /forum/post/11909968
I just built the one from uhfhdtvantenna.blogspot.com, mounted it in my attic with a Magnavox rotator, and it works great! I went from an average of 50% signal strength to consistent 80 and 90% ranges.
Originally Posted by MClever /forum/post/11921187
I used 300 ohm twin lead wire (2 equal lengths) direct to 300 ohm input/ 75 ohm output preamp to eliminate balun/combiner loss.
Originally Posted by Falcon_77 /forum/post/11927308
This was for a 4-bay, right? With an 8-bay, I suppose I could do this, but I would still have the radiating feeder lines to deal with. Running 300 ohm twin lead to each side would not seem to be practical?
Originally Posted by nybbler /forum/post/11924954
Right, they aren't weatherproof at all. The other thing is that the CM4221 is pretty cheap so you're just not saving all that much if you don't have all the parts lying around. It's fun to play with.
I decided to see just how crappy an antenna would work .
Originally Posted by MClever /forum/post/11932768
For me the DIY 8-bay would not pull in the long distance stations as the 4-bay, so I've stopped messing with it. It could be the multipath or probably an error in assembly on my part.
Originally Posted by NightHawk /forum/post/11941134
You're not saving anything there. By using the 300 Ohm input your simply going through an internal balun anyway. The pre-amp itself will be unbalanced and the balanced line must be converted somewhere.
Originally Posted by Whidbey /forum/post/11914287
I wondered the same thing but I think the only way to get an answer is to do it myself. Gotta admit if I had known about how I could have built my own 4228, I may have given it a shot before buying. Oh well, the 4228 looks better on my roof than 2 x 4's and chicken wire.
James
Originally Posted by lemmalone /forum/post/11944718
I assumed that MClever has only a 300ohm input on his amp, and thus saved unnecessary conversions from 300 to 75 to 300 to 75 again
Originally Posted by NightHawk /forum/post/11948733
I have't seen a commerical pre-amp with only a 300 Ohm input.
