I am beginning my upgrade quest in earnest, beginning with an emphasis on multichannel performance for HT. To that end, I will be upgrading my speakers (to Aurum Cantus Supremes, Rhythm and V2Ms for surround duties), adding a multichannel amp (Plinius Odeon) and swopping out my subwoofer (either a Velodyne DD-18 or the JL Audio Fathom F113) within the next few months.
For the moment, I intend to continue using my Denon 2805 as a pre/pro until a wider selection of pre/pros with HDMI inputs are available for next-gen audio formats. I personally do not need HDMI 1.3 but it seems as though all the high end audio companies are awaiting finalisation of 1.3 before they release their HDMI-equipped decks. I'm sort of tempted by the Cary Cinema 11 but am hesitant because I've read that they are working on a higher-end model and also because, to take advantage of the advanced audio codecs, one will also need to buy the as-yet unreleased Cary video processor (which is a component I'm not particularly keen on adding as I've come to the conclusion that it is infinitely more worthwhile to spend $$$ on the audio side of things since the technology does not become obsolete nearly as quickly as on the video side of HT).
Anyhow, my question is: what do I upgrade next after the multichannel amp (or perhaps even before)? I currently have a Sonos system hooked up to my Denon 2805 and have begun ripping my CDs in lossless format. What should I add next? An external DAC for the Sonos or a stereo pre-amp (again, primarily to use its DACs for the Sonos)? Please excuse my ignorance but what are the advantages of a pre-amp over an external DAC and vice versa? Will it be necessary to eventually get both?
After that, my next big question will be whether to upgrade to 7.1 or to biamp the front 3 channels by adding tube amps and an active crossover. But until then, I'll be grateful for any advice on my present question.
, so I can't really spend too much on the room since I don't know where I will be moving to next (size, room configuration etc.) When I eventually buy my own place, room treatment will certainly be top on my agenda.
