AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Parasound P7?
Parasound P7? - Page 6
post #151 of 156
Originally Posted by Brad Levine View Post
What would this do for me? Make my speakers sound better?
No. Its for switching sources and controlling the volume of sources, just like an AVR only without surround sound. To improve the sound of your speakers you either need room treatments and/or new speakers.
Edited by Theresa - 1/1/13 at 3:24am
post #152 of 156
I assume you are now asking about adding a power amp Brad. Much more information would be needed in order to answer your question rather than make any kind of blanket statement. Would need to know the make and model of your speakers along with sensitibity and mpedence. Also, how big is your room and how loud do you like to listen? Depending on these answers, you may or may not see any improvement in adding a power amp.
At least you have an answer to your original question about acquiring a P7. You now understand that you don't need one because you already have a fine AVR in your Pioneer VSX-53. Best of luck in your audio journey and Happy New Year!
post #153 of 156
I just don't see why it would be worth it then. I'll prob just wind up waiting till i can get a preamp and processor.
post #154 of 156
Kinda resurrecting a dead thread here but I was wondering about this....
Something like the P7 would make alot more sense compared to many of the preamps today if you mainly cared about the sound of your system?
I dont care about DLNA, Vudu, etc. through my receiver...I care about the sound
I can always go audio from my bluray player to the P7 and the HDMI to the the TV/Projector to have the high res picture...
I just feel like today with technology moving as fast as it is we cannot stay ahead of it by constantly buying receivers that attempt to do EVERYTHING.
Honestly the areas that need most of the EQ in a system is in the low frequencies so buy a seperate one and run the audio from the sub out in the P7 to the EQ and then to the Sub...this will probably also give you more control over the subwoofer anyways....
Also the auto-EQ does not get your systems 100% correct anyways...can I do better without it? Probably not without some trial and error but I would rather have great sound than anything else....
Also, in my eyes, it would be cheaper to just replace a bluray player/display to go to 4K for instance than to have to upgrade everything....
post #155 of 156
I would think an Oppo 105 with a P7 would make an awesome system. If your sub does not have EQ (e.g. Velodyne) then add an Antimode. I don't use Audyssey for music anyway.
post #156 of 156
I went this route with a mutichannel preamp years ago and it performed admirably. There are a few other made by Macintosh, pathos, audio refinement, copland and audio research. Actually when I compared it to various receivers it performed noticeably better. I was enamored of the anthem pre/pro but my budget didn't allow. It definitely was better for music to use my audio refinement pre5.
I had to search back quite a few years but I also found the marantz dp870 DD pre/pro. I think Macintosh and rotel made one too. Very handy to have DD for your cable tv (football) integrated as well to your HT and a simple processor that added nothing except DD functionality. the marantz was the only one with a bypass if you don't have dual mutichannel inputs preamp like the para sound P7.
In a purist HT you only need the oppo and cable. The receivers do integrate better with lifestyle wants (wireless, online media, ripped/downloaded content and multi zone). Not to mention the lifestyle approach is just cleaner cable wise. Since i moved to a new home, the HT room is mixed use now and not a dedicated theatre. . Even I admit to going back to a receiver (NAD). But it is still using an extra 6 RCA's since I use an external amp.
I did take the separates route to the extreme. Having an external bass management and a separate video processor in the old HT.
Edited by poopiehead - 4/27/13 at 4:00am
