I'm ready to tackle my first DIY sub & hope to get a little last minute advice before I purchase the sonotube & driver. Here's my questions:
I already have a SVS CS Ultra powered by 1 channel of a Samson S1000 (500w into 4 ohms). I will run the sonosub off of the 2nd channel of the Samson amp.
1. Based on 500w, would you recommend a SS RL P15 (D2) or a 15" TC 2000 Single voice coil?
2. I assume I'll end up in the neighborhood of 320 litres...would you recommend 24" diameter sonotube or 20" sonotube? I'm not really concerned about height / size...what ever will be easiest / best.
3. I've read that most people line the inside of the sonotube with insulation or batting. I have some "linacoustic" insulation on hand...can I use that? It's about 3/4" thick w/ fiberglass on 1 side & a backing on the other side.
Thanks!!!
Thanks!!!
If that's what you're seeing on your end too, then the driver parameters are wrong. Try these... I can't say they're perfect, but should be close.
