I need a cable about 50' in length to go all the way around my room to my pj. my pj supports hdmi and my pc is DVI, is it best to have a long hdmi cable (as its smaller) then convert to dvi at the pc, or long dvi then convert to hdmi at the projector?
are there any drawbacks to either one? seems due to flexability the hdmi would be the better choice, but smaller cable at those length might cause signal loss.
War
EDIT: also want to know what kind of quality/signal loss would i expect using a converter on either cable? how much diff would it be to get a cable with both ends i need hdmi >dvi? I prefer the converter as i can use it as just hdmi cable without converter, or convert it when i connect it to the pc. also since i hope to get a hdmi switching reciever soon.
War
At this length, fiber optic or CAT5 solutions are the best way to go, but usually more expensive, if you want to run cable once, and once only. There are also cables made with "amplifiers" in the connector (expensive too) and some switches will amplify.
