Originally Posted by HTDepot
i) The BriteG has the same viewing angle as the High Power screen from Da-Lite.
ii) I would not recommend this as for this material cannot be stretched like that of a fixed frame or a Tab Tension screen. You would have a really hard time making sure the fabric is completely flat. You would also run the risk of creasing / cracking the glass beads in the fabric during the process.
What kind of projector are you using? What is your throw distance? Describe the lighting in your room.
Thanks Alex
This is my smallish HT room. I have a Marantz VP4001 pj which is a short throw projector which gives me 120" from 12 feet away. Note I have a open wall not pictured here where is open to big windows so during the day, I have some ambient light coming into the room from the left hand side. No light hits the screen though....its more like ambient lighting that lightly floods the screen but enough to wash out the picture during daytime.
This shot perhaps indicate better....taken during the day. You can see how the screen is a little washed out (my HTPC desktop). Its watchable but I'm hoping a high gain screen like the High Power or the BriteG screen would benefit me more with the added gain/brightness, specifically for daytime PJ watching.
developed a switcher that comes with a 12Volt trigger option; we are receiving them in about 7 days. The new screens will have this option already build into them (with an additional wall switch available).
and test out our available fabrics!
