AVS › AVS Forum › Video Components › Cable, Digital Cable - Non-HDTV › Time Warner Cable DVR
post #1 of 9
Hello all I just picked up a Time Warner DVR for my Mom. Its a SA 8300 running passport software. I am a Cox tech and tried to get into the diagnostic menu using the Cox buttons but it did not work. I was wondering if anyone could help me out with this. I also was wondering if there is a way to enable the AUX input on the box.
Thanks Andrew
post #2 of 9
AUX input isn't enabled on any SA boxes firmware so far.
post #3 of 9
I have used the aux inputs on the Cox models so I guess its just eh TWC box's. I use it if the tv has only one input, I done it many time during installations.
post #4 of 9
Sure it is. I'm using it right now. I have 2 SA 8300HDs from Time Warner running SARA and it's enabled on both. With the cable box on and the remote in cable mode I just hit the Video Source button and it takes me to Aux In on the front display it reads Au.
post #5 of 9
Ah, then it must be a new feature of SARA only. I've got Passport and they don't have such a feature.
post #6 of 9
Then Passport sucks. Which, unfortunately, is what I've got too.
Was rather hoping that those inputs would be made live at some point.
post #7 of 9
hey guys..... this is exactly what i was trying to figure out...... I'd like to utilize Aux inputs on TWC DVR (passport software???).... when I hit the video source button nothing happens..... what do I need to do????? Thanx!!!!
post #8 of 9
use your remote and enter 999 for the diagnostic screen
post #9 of 9
I actually called TWC & they said the aux inputs are inactive & they don't know if & when they'll be active..... I'll try that diagnostics page just to see what's there.... thanx
  Back to Forum: Cable, Digital Cable - Non-HDTV
