AVS › AVS Forum › A/V Control & Automation › Home A/V Distribution › Russound VM1 - Release Dates ?
post #1 of 19
Does anyone have any release dates for the Russound component video switcher over cat 5. It is called the VM1 and it was announced nearly a year ago; but russound has gone silent on it.
post #2 of 19
I was told June/July 2007 last week by Russound.
post #3 of 19
It looks like the VM1 is now available from Russound, as they have it listed on their website under distributed video solutions.
Can anyone confirm this, and if so, does anyone have pricing for these units?
post #4 of 19
According to Russound Sales - September 28th is the tentative release date.
post #5 of 19
I'm hearing that it won't be available to ship until September...
Cheers,
Paul
post #6 of 19
MSRP of the various choices?
post #7 of 19
They announced this a year ago with pricing but I can not seem to find it. I remember that the high end model was going for approximately $2k. If I can find my notes - I will post again
post #8 of 19
Any reason they chose to make the VM1 4x4 and 8x8? I'm going to be hooking this into my CAV6.6 Won't I either have 2 in/outputs to few or too many?
post #9 of 19
Here's the retail pricing... this includes the VM1R wall plates:
$2190 - 4x4 no upconvert
$2790 - 4x4 with 2 source upconvert
$3390 - 8x8 no upconvert
$3990 - 8x8 with 2 source upconvert
$4590 - 8x8 with 4 source upconvert
PK
post #10 of 19
Most people have a number of "non-video" sources... I bet you do too?
If you have a CAV6.6 with six sources and on is a CD player, one is XM radio and one is AM/FM radio, then you really only have 3 video sources and will have one source input left over on the 4x4 model.
The 8x8 switch will work with systems that have more than one CAV/CAM controller and the 7th & 8th zones will match up with zones 1 & 2 on the second controller.
Remember that the VM1 switches can be controller via RS-232 so if connected to an external controller you could manipulate the extra inputs & outputs that way too.
Cheers,
Paul
post #11 of 19
my problem with this sysyem is 1080p with component. Bluray wont do it and the major manufactures are pushing HDMI, is the system worth the price?
post #12 of 19
That will give you your 8 zones but what about your 8 sources? Typically if you have 2 CAV6.6 's don't you still have 6 sources but 12 zones or am I misunderstanding it.
post #13 of 19
Are there any switches that provide similar functionality for high definition zone distribution over cat 5 and HDMI. I don't like the price/performance (component - distribution) either.
post #14 of 19
Yes, you're correct. Even with 2 CAV6.6's you're still limited to the six sources. You can use a 7th source if you enable the front panel A/V input .... this means you're only loosing one source input on the 8x8 switch.
It sounds like many are wondering why Russound is releasing an 8x8 switch when it's not a very good fit with any of it's current products? The big picture answer is that it's not an exact fit with any of the current products, but I expect that it may be a perfect fit with "future" products...
Cheers,
Paul
post #15 of 19
I'm not aware of anyone currently offering an HDMI matrix switch that can send singnal over distance using CAT5 (or anything else).
There's been some discussion of this in the past in other threads and distribution of HD over HDMI just doesn't seem viable yet. It was really developed as a local interconnect, so will be interesting as time marches on to see what can replace component video for distribution in the future.
Cheers,
Paul
post #16 of 19
Another thing to remember as you thinking/dreaming about your Russound HD distribution...
The HD sources need to output to the lowest common demoninator that you displays will support.
For example: If you have 4 displays, one 1080p, two 1080i and one 720p, all your sources will need to be set to output 720p to work. Since this is a matrix switch, if any of your sources are outputting a resolution higher than the lowest res screen can support, you'll run into problems.
Food for thought and needs to be considered during planning...
Cheers,
Paul
post #17 of 19
Any reports on how well the VM1 works? I no longer have my Avatrix, so I am looking for something else. I have a CAV so integrating the VM1 with the existing CAV should be easier than other solutions (maybe, maybe not).
post #18 of 19
The VM1 has been shipping for a little over a month now. I had three of them on pre-order for customers which were all received the first and second week of October.
One of the three units failed within the first 48hrs of use. It was replaced and the new unit has been working without issue.
Picture quality is excellent and they're a snap to install... seems worth the wait!
Cheers,
Paul
post #19 of 19
I am the customer Paul referred to in the previous post. I am extremely pleased with the VM1. Easy to install - make sure you read the brief few page manual. Up conversion works, switching works, picture is great over long runs. if you install yourself makes sure you are good with cat5 (i.e. termination of cables). I am extremely pleased with this unit.
SBS/Paul was great in getting me a replacement unit under warranty -- also pricing and responsiveness was great from SBS.
Note - make sure you order from authorized dealer to insure that warranty is valid.
  Back to Forum: Home A/V Distribution
