I installed the Xantech 291-Kit yesterday. The receiver (291-00) sits beneath the screen and the equipment room is in the back, so i had to cut the connector off the receiver and run 24ga wire to the equipment room (about 30 feet).
I forgot to check the LED status before I cut the wire, so I don't know if the LED should be constantly lit as it is now. The LED flashes brighter when I send it a command, and everything works. I double-checked the wiring and everything's right.
I really don't want to fry the system so I appreciate any input you guys might have.
Avquest
Avquest
