AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › OFFICIAL Hsu MBM-12 thread
OFFICIAL Hsu MBM-12 thread - Page 5
post #121 of 453
Here is a site done by DrPainMD for setting up a home theater. It covers just about everything you would want to know: http://www.avsforum.com/avs-vb/showthread.php?t=824554.
Bill
post #122 of 453
hi all.
i'm not getting much midbass from my infinity beta 6.5 inch bookshelf speakers. shocking i know.
would i be better off buying three towers for LCR (i've heard them and they seem good for midbass) for almost $1k total or buying the mbm-12 for $500?
room is small. about 120 sq feet but it's only for HT
post #123 of 453
Originally Posted by union1411 View Post
hi all.
My vote goes for a MBM. No $1k tower will move as much air as a MBM. In addition, a MBM can be placed nearfield (tower cannot) for even more impact.
post #124 of 453
it's $1k total for 3 towers (each with dual 8 inch woofers; the Beta 50s), but thanks for the post. i'll give the mbm-12 a try. i should doing some measurements with REW but i've been lazy. definitely will try the mbm-12, esp since it has 30 day money back. thanks.
post #125 of 453
hi all.
I not heard the the towers you reference but I have Polk RTi8s and before I received my second MBM I ran one upfront and the true sub behind LP. It was a huge improvement in mid-bass, adding the second made it insane and I have over 4200cf in my room.
I did not like the MBM behind LP, too localized and could not feel the deep bass with true sub upfront.
Settings now are AVR xo at 120hz, MBMs xo set to out and true sub xo set to 60 hz(sometimes set it to 45hz, depends on what I am listening to)
I would think 1 MBM in your room would give you the mid-bass you desire. If you do not like it I am sure you will have no problem selling it. I know a guy chomping at the bit to buy a used one but if one does not come along soon he will most likely buy a new one.
post #126 of 453
thanks. what does LP mean? where do you have your MBMs located now?
post #127 of 453
what does LP mean?
LP = Listening Position
post #128 of 453
sweetspot aka Listening Position. I have 1 MBM up front with each main.
post #129 of 453
Been reading and thinking about this unit for more than a year, and finally gave in late last night and placed the order. Just as HSU says, in my room I find the best sub placement for deep bass is the left front corner but this has proven to not be the best for the 'slam' region from 40-80hz. I think having a midbass module with separate level control is going to be the solution to getting the 'punch' I'm craving.
I'll try the MBM-12 centered between my mains about 7ft from the listening position which will keep it pretty close to time alignment with the sub and speakers and will allow experimentation with a higher crossover, and will also try it directly behind my listening chair with an 80hz crossover since this is how the Dr. had it set up at the shows that have elicted rave reviews.
I mentioned in the order notes the returning customer discount on the MBM-12 (purchased dual VTF-3.3's and Turbos in 2006/07) that I've read about in the forums, hope that is still going on
Cheers,
Ross
post #130 of 453
Cheers,
Ross
Good choice. I have mine set up the same way.
post #131 of 453
rossandwendy,
what are your mains subs now?
post #132 of 453
anyone running the mbm and buttkickers? i'm wondering if one will make the other somewhat redundant.
also, how would i wire the mbm and buttkickers from the receiver's LFE out? Y splitter to another Y splitter?
post #133 of 453
Originally Posted by ribbit View Post
rossandwendy,
Currently running a Conquest and really liking it, but still have dual PB13's here and may try those with the MBM also.
Cheers,
Ross
post #134 of 453
Cheers,
Ross
thanks, please keep us up to date on how the MBM affects your listening. like you, i'm looking for that "punch"
post #135 of 453
My duel MBM-12's are scheduled to be delivered tomorrow. I will be trying them out with my current pair of HGS-18's. According to the shipping company my Conquests have an estimated delivery of the 18th.
First I will be trying them out placed up front with my mains since I am using Buttkickers for the seating.
I have the tactile transducers fed from one of the 2 auxilliary programmable channels of a Parasound C2. The channels can be fed a user-selectable mix of signals from the other 7.1 channels. Each has independently adjustable duel high-pass and duel low-pass filters in 5 Hz increments, delay, gain and provision for deriving content from any or all of the other eight channels, mixed in any proportion and configuration in or out of phase.
The TT's are receiving signals from all channels lowpassed at 20 Hz with an independent delay from my subwoofers..
I am thinking about using the 2nd programmable channel to feed the MBM's. This will give me a considerable amount of flexibility.
John
post #136 of 453
John
That's some nice flexibility you got there John. Looking forward to your comments on both the Conquests and the MBM's.
Cheers,
Ross
post #137 of 453
Will do. It's interesting to me that even with really good subs such as the Ultra and Conquest, there is still a desire for more of that chest-pounding slamming midbass...I think that is a key aspect in an HT system that has truly high impact, more important for sure than the sub-20hz stuff IMO. I hope the MBM12 can provide this...
Cheers,
Ross
post #138 of 453
My duel MBM's arrived this afternoon and I positioned them up front with my mains. One just inside each main. I am currently using them with a pair of Velodyne HGS-18's. Duel Conquests are scheduled for delivery on the 18th.
Connection configuration - Processors Sub Out --> Anti-Mode 8033B --> MBM-12's/HGS18's
I began the setup process with the crossovers in both MBM-12's and both HGS-18's bypassed.
Turning them on and off one at a time I set each of their gains to match using pink noise.
I engaged the lowpass crossovers on the HGS-18's at 50hz. I left the MBM-12's crossovers bypassed.
Turning them all on I then used the Anti-Mode 8033B to correct the room.
Finally I set the entire MBM-12's/HGS-18's groups combined gain to match the rest of the channels.
I haven't experimented with nearfield placement or connecting them to a programmable channel yet.
I have a very diffucult room that is basically square.
15' 8" D x 15' 11" W x 8' H Sealed
Carpet over cement, drywall, 2 walls are insulated exterior. The window well is stuffed with 3" of foam
and covered with solid panel shutters. LP is 3' from rear wall.
John
post #139 of 453
John, that is absolutely beautiful! I am very jealous. Have tried bypassing the 8033 to see how much it helped?
post #140 of 453
very nice John!
your initial comments?
the HGS-18's you have are right smack in the corners, no space from the walls? did you ever try to move them away from the corners?
post #141 of 453
Thanks for the compliments.
weverb,
I haven't had much time to experiment with the 8033's bypass since I added the MBM's this afternoon.
ribbit,
The HGS-18's have been up front in the corners for a few years. It use to be
The Bedroom HT
I will definitely have to rearrange them when the Conquests arrive.
John
post #142 of 453
John,
Tell me more as you get to play. I am very interested in the same unit. I am still tweaking my current set-up before introducing some type of BFD. I may not need it, but still want to hear your impressions.
post #143 of 453
My duel MBM's arrived this afternoon...
What is you center channel sitting on? I have a DT 2300 and would love to get it angled in a similar way.
post #144 of 453
John
What kind of mains are those?
post #145 of 453
Def Tech BPs
post #146 of 453
MBM has officially shipped. i feel like i'm now part of a small family of midbass freaks there can't be that many of us in the world.
post #147 of 453
Let the addiction begin! Fortunately we have a very good support group you are joining. You will know that you have a real problem you start talking about adding a second, third,......
post #148 of 453
Originally Posted by Pharcyde23 View Post
Def Tech BPs
Yes BP2000 TL's
Lovan M2
That's a Def Tech C/L/R 3000 on top.
John
post #149 of 453
so, my svs pb10 doesn't have a crossover on it. hsu mentioned that a F-Mod might work. anyone know if there are any significant downsides to that approach? i plan on upgrading to a new true sub soon, but for now it's the svs.
post #150 of 453
I have done a little more experimenting with placement. As metioned I started out with the MBM's up front with my mains. In this position I actually heard them struggling a bit on demanding material. I listen to all my material
-7 dB below reference.
This evening I placed them nearfield directly behind the listening position. I engaged the internal lowpass at 80 hz. I used a programmable channel and was able to take advantage of a separate delay.
Then I pulled my HGS-18's out of the corners and placed them up front with my mains with the MBM's still nearfield.
Currently I am testing eveything in the rear of the room. The MBM-12's are still behind the listening position lowpassed at 80 hz and the HGS-18's are on each side lowpassed at 55 Hz.
Each time something was moved I matched the 4 subwoofers gain levels and re-ran the anti-mode 8033B room correction. Then recalibrated subwoofer levels to match the system.
I still need to do some more experimentation. I do like this last configuration the best. Even in the first configuration it did smooth out the bass in the room. No more localization issues I was experiencing.
This leaves the front corners open for the Conquests when they arrive early this week. Due to their size it might be the only place for them.
I plan on removing that recliner platform and staining it Bombay Mahogany.
John
