What kind of EQ software is needed to spl match the mbm gain to mains if you use the mbm to extend the range on the mains?
Would a standard disk like an avia and an SPL meter be ok?
I have a small room with MASSIVE subs and am getting 2 jtr tripple 8's to run l/r with a phantom center. I was considering betting an MBM to run from about 60hz to 120hz. I would send all the signal from the fronts from 60 down to the big boys and everything from the sides from 80 down as well as all LFE content. i just want so close up punch.
Will an mbm even provide anything my 3 18" can't provide considering the jtr's need to be crossed at 100hz (pretty high)?
(thinking of the Trancducer?) tho sometimes i think thers something wrong, i seem to go def around women
