Originally Posted by
Raul GS
Surely you must know we are talking about degrees of adaptation. Have you _never_ adapted to sound that initially was somewhat loud? Does your hearing _ever_ change day-to-day? Did you know that your eyes also adapt to color miscalibration (do you ever wear tinted glasses?)
My hearing only changes if I go outside. I lock myself up in my room to get consistency in listening to my audio system.
If I go outside riding in the wind and then come back to listen to my audio system it sounds like 1dB lower volume. After a day it sounds about 0.7dB higher than before, on the 3rd day little lower again, on the 4th day little higher again. It's like a wave that goes up and down that eventually stabilizes. But as long as you are aware of it it's not that big of an issue.
Raul GS
This is
great you could make some decent cash and maybe even get an article published in a refereed journal if this pertains to cables in some context (and judging by past comments, it probably does). You should set up a double blind test with some of these objectivists (they are suckers, they are willing to pay you thousands of $ if you are right), all that is required is that your equipment be operating within proper parameters and that you be willing to pay if you happened to be wrong (which is impossible because the differences are
unbearable to you). You should go ahead and just show those self-righteous/sanctimonious how ignorant and stupid (since they are going to give you thousands of $, for such an obviously easy test to pass) they are, and finally help cleanse audio discussion of their dribble.
I have already done a double blind test and captured it on video, skeptics like to ignore the truth.
http://www.head-fi.org/forums/showthread.php?t=207222
On the last trial of Valhalla vs stock the ambient room temperature had changed which made me give a different answer. Now I'm aware of more variables of what affects the sound, next time I make the test it's going to be 100%.
With the 8 power cord test I heard something was wrong, it didn't sound like last time I tried the cable, see the video.
The test needs to be properly done, if there's an earthquake or something else, it's not going to be an accurate test. Skeptics like to ignore that.
