Hello.
I have 2 ReplayTV 45XX series that I have networked.
Each ReplayTV is able to see the other one through the LAN as well as see all the recorded shows.
However the problem is that:
1. Its unable to play shows. It will give the error: Unable to play show or unable to contact other replaytv.
2. Its extremely slow. There is like a 10 second LAG time to navigate around the screen.
I have upgraded my ReplayTVs with 500 GB hard drives and have them almost 100% filled with shows. Is this a common problem with large hard drive in ReplayTV? Perhaps the RAM or CPU is unable to handle so many shows at once?
I'm able to stream ok with DVarchive without problem however I can't stream from 1 replaytv to another Replaytv for some reason.
If there are any suggestions, workarounds or even knowledge as to what is causing this problem. I would sure appreciate it!
Thanks you everyone for your help!
