Anyone know anything about this upcoming product released this month?
$449 for upscaling to 1080p seems great if it can perform.....
Features:
* Both digital and analog inputs are format converted and pixel re-scaled through the Home Theater Scaler. It outputs a large range of formats and resolutions that will easily match the native resolution/ format of your display to ensure highest picture quality.
* DVI/HDCP/HDMI compliant input: Operates up to 165Mhz (Up to UXGA @60Hz)
* Supports digital HD output up to 1080p.
* Integrated 8-bit triple-ADC/PLL.
* Integrated DVI/HDCP/HDMI compliant receiver.
* Dual high quality scaling engines.
* Dual 3-D motion video adaptive de-interlacers with smooth low-angle edge.
* Automatic 3:2 pull-down & 2:2 pull-down detection and recovery.
* High performance frame rate conversion engine.
* The Proprietary Advanced Color Engine technology gives: Brilliant and fresh color, Intensified contrast and details, Vivid skin tone, Sharp edge, Accurate and independent color control
* Option to select Audio input from HDMI or TOSlink/SPDIF audio source.
* 3D noise reduction on analog inputs only.
* Operates through on-screen OSD menu control and remote control.
Specifications:
* Digital Video Amplifier Bandwidth: 1.65 Gbps
* Component Video Bandwidth: 350 Mhz
* Input DDC Signal: 5 volts p-p (TTL)
* Input Video Signal: 1.2 volts p-p
* Single Link Range: 1080p/1920 x 1200
* Input/Output HDMI Connector: type A 19 pin female
* Component Video Connector: 3 RCA
* Digital Audio Connector: optical TOSlink
* Analog Audio Connector: mini-phone stereo 3.5mm
* Power Supply: 5V DC
* Power Consumption: 20 watts (max)
* Dimensions: 6.875"W x 2.125"H x 6.875"D
* Shipping Weight: 6 lbs.
Features:
Specifications:
But The Sharp Does A Sub Par Job Of Up Converting
Is it "the best" no but it is much better than the $.0001 chip that some TVs have.
