Been wanting to write a review of my new screen and decided that today, a day after watching the super bowl, it was time to get to it. Now I got the upgrade itch around Christmas and I decided to sell my old Z2 and get the new HD1000. I also decided to try out a new screen. My old screen wasn't some DIY white wall or a cheap screen, but it wasn't a Stewark Greyhawk either. I had (actually still have) a Draper Luma 2 gray screen. It's been a nice performer. Does all the things a gray screen should, better blacks, better color saturation, and it's a very smooth screen since it's not beaded to create a boost in gain. It's actually rated at .8 gain. With the HD1000's extra brightness the whites had improved over the Z2 and the set-up looked nice. But I still had the upgrade itch.
I became interested in a painted solution and begain searching through the DIY screen section here at AVS. Well, there are all kinds of options. I began to examine my DIY abilities and question whether I could really pull any of this off, and do it well enough that it would look good. Then I stumbled on XFS and the Black Flame expanded PVC screen.
So, being in the "sounds good so let's take a chance mood," I ordered. It took a few weeks, but I eventually got my XFS Black Flame screen. I had built a black frame for it out of hardboard and painted it black (about the most my DIY abilities could handle.) With a little velcro I hung it all up on the wall. XFS Black Flame is a painted screen. The paint mixture, created for this screen, is sprayed ontop of expanded PVC (sinatra board.) or ontop of an acrylic mirror (Black Flame Light Fusion.) The screen is very light and tacks up easily. A fixed frame is nice because it looks like a giant plasma. And the painted surface is super-smooth. So far so good. Now I still had my old screen rolled up overtop so I could A/B compare images.
I started with a high ambient light situation - full daylight and I have lots of windows. Well, XFS Black Flame was slightly better than the Draper gray screen, but not by a lot. It maintained a little better brightness and color saturation. Not a huge improvement, but some. Next, I watched in a moderately dark environment with a bit of illumination in the room. Here the seperation began to really become more visible. XFS Black Flame offered slightly better blacks (and remember I'm compairing it to a gray screen,). However, color saturation and pop became apparently better. Colors really jumped off the screen. And then - the whites. WOW, bright Plasma-bright, whites. Here's where XFS Black Flame really departed from the .8 gain gray screen. It showed better whites than a white screen (had a basic Da-lite matte white screen to also compare with.) With the darkened blacks, improved color and depth, and the brilliant whites the image seemed to be a giant plasma. That's when I started to appreciate the upgrade. XFS allowed me, not a capable DIYer, to get the great DIY results that painted surfaces offer.
I had two anti-front projection friends over for the super bowl and they were finally impressed. They had both seen the HD1000 on the Draper last week and liked it (noticed the improvement over the Z2) but weren't ready to come on over from plasma and into front projection. But when we fired up the superbowl even when we had the lights on they were impressed. As the game started and we darkened the room. WOW. The colors in the Prince performance were outstanding. (BTW did it seem to anyone else that they had gotten more bandwidth on HDTV. The compression looked much better than I've seen during the season? I have digital cable.) The plasma boys were both looking differently at front projection. Considering the price of the whole set-up vs. the price of a 60" plasma that's still 25" smaller than my 85" screen, who wouldn't wonder, why spend $6000?
In summary, if you like fixed frame vs. having the hide away of a pull down screen you should take a look. Also plan on doing a black frame. It really makes all the difference and is one of the easiest ways to make your screen look better. If you already have a cheap pulldown screen or a not-so-hot DIY screen, this might be worth the look. If, however, you don't have a screen and are looking at options I
REALLY
think it's worth a look. If I had to qualify the improvement I'd say 25%-35% better than the Draper Luma 2 gray screen. XFS Black Flame gives you the best of a gray screen and the best of a white screen and does both of these functions better than either one can by itself.
In terms of similarly priced competition: you have screens like my Draper, which just can't give you plasma like whites. The Greywolf II which from my research seemed to introduce to much texture into the image since it is beaded to boost gain (although I've not seen it myself. I was worried about the texture many reviews here at AVS have commented about.) Or you have the Da-lite Hi-Power. Lots of plasma bright whiteness but you have to deal with the narrow viewing cone which was a major downer for me. And if you're ceiling mounted you won't be able to take advantage of the extra-gain boost since the screen is retro-reflective (shoots light back to where it came from. So If you ceiling mount the light will be reflecting mostly back up to the ceiling.) And to be fair: Silverstar, Stewart, DNP Supernova are all so dramatically more expensive it wasn't worth the thought for me. There are interesting comparisons being made, however, between XFS Black Flame and these super screen performers.
I actually forgot to mention the viewing cone of XFS Black Flame. As I moved around the room changing viewing angles there seemed to be very little if almost any viewing cone. It was certainly as wide as the Draper so no seeting problems here. The screen itself is a silver/gray that has a little sheen but is basically a matte finish. There is no gain on the top of the screen. The bright white of the expanded PVC underneath the paint reflects the strongest light (like bright whites). This is where the modest boost of gain comes in. I'd say it's a 1-1.5 gain just eye-balling it.
So, on the performance/value scale XFS Black Flame is exciting. I'd say it's worth the look and your own personal research. Customer service was good, but it's not like buying off the shelf from one of the big guys. It'll take some time but I found the whole experience to be postive. You're getting a personal service from someone who seems to really care and take pride in making the screens. Obviously, no screen is perfect for everyone. Some will really prefer a pull-down, or want to try and save a little money and DIY it, but I've been impressed with the results
XFS website:
http://www.xtreme-fusion-screens.com/
Nathan Troutman
N2T@juno.com
REALLY
think it's worth a look. If I had to qualify the improvement I'd say 25%-35% better than the Draper Luma 2 gray screen. XFS Black Flame gives you the best of a gray screen and the best of a white screen and does both of these functions better than either one can by itself.In terms of similarly priced competition: you have screens like my Draper, which just can't give you plasma like whites. The Greywolf II which from my research seemed to introduce to much texture into the image since it is beaded to boost gain (although I've not seen it myself. I was worried about the texture many reviews here at AVS have commented about.) Or you have the Da-lite Hi-Power. Lots of plasma bright whiteness but you have to deal with the narrow viewing cone which was a major downer for me. And if you're ceiling mounted you won't be able to take advantage of the extra-gain boost since the screen is retro-reflective (shoots light back to where it came from. So If you ceiling mount the light will be reflecting mostly back up to the ceiling.) And to be fair: Silverstar, Stewart, DNP Supernova are all so dramatically more expensive it wasn't worth the thought for me. There are interesting comparisons being made, however, between XFS Black Flame and these super screen performers.
XFS website:
Nathan Troutman
N2T@juno.com
