I don't where to find the perfect entertainment center. Maybe I can get some ideas from you guys.... I am buying the KDS-R60XBR2 LCoS Sony projection TV. 60" about 22" deep.
I have a large Bose system (older version) with a large subwoofer. I am looking for a low to the ground TV stand that can hold the TV I am buying. I would like to have one of those central compartments that houses the Subwoofer in it with the black cloth covering over it. I also want their to be shelves on the side of it. I would also like their to be a seperate matching tower with it, one that I can put away from the TV if I want. I want this to have adjustable shelves and it will hold my Cable box, PS3 and a very large receiver eventually. I would like it wood though...I don't like the ones that are metal and glass with open shelving. I would like it closed in....the hard part is finding one that has a subwoofer compartment...and a side tower for AV equipment with a glass door....
Plus I dont want to spend alot on it...any ideas where I can find something like this?
