Originally Posted by
DVDO+WESTY=1080p
I picked up my XA2 from Tweeter and I plugged in the audio with 6 ch analog out. For some reason the center channel is coming out of the rt surround and other sounds are off. I have checked all the connections and they are where they are supposed to be. Does anyone else have this problem?
I had the same problem. I had plugged the center and sub cables into the wrong jacks at the back of the HD XA2. Its confusing when you look at teh marks on the back of the player, even more so after you already have plugged in the front speaker cables.
You get exactly what you describe if you plug in the center cable and teh subwoofer cable into the rear surround inputs.
Oops. I did it myself, and check it three times before I took all the cables out and looked at the diagram on page 26 of the manual.
If you just seen the markings , you probably did what I did and assume the 5.1 surround marking referred to the bottom row and the center and subwoofer markings refer to the lower row. They do not.
The center and subwoofer are the LOWER row. the "5.1 channel surround" marking refer to the entire set of 6 inputs. If you look on page 26 of the manual you will see what I mean.
I had the same problem myself when I first set it up. I plugged the wrong out puts in.
It looks like the center channel and subwoofer outputs are in the middle row, because they have the words underneath them, but they actually are still on the bottom row. (ch2 pg26)
http://akamaipix.crutchfield.com/Man...2/052HDXA2.PDF
The 5.1 audio inputs in each row from top to bottom are
(Front Right) (Front Left)
(Rear Right) (Rear Left)
(Center) (Subwoofer)
Its confused me because the lettering between for center and sub is between the first and second rows.
(O) is the input jack hole
Code:
R L
(O) (O) FRONT
I I
(O) (O) SURROUND
CENTER SUBWOOFER
(O) (O)
5.1 CH SURROUND
