AVS › AVS Forum › Audio › Speakers › Official AV123/Onix Owners Thread: TECHNICAL TALK ONLY
Official AV123/Onix Owners Thread: TECHNICAL TALK ONLY - Page 55
post #1621 of 1714
Originally Posted by tdogroeder View Post
What do you mean by they are "adaptive dipole"?
The RSS300 has 4 speakers: a woofer and a tweeter on each side. Only the tweeter is wired out of phase. The 2 woofers and the other tweeter are in phase. A full dipole would have had the woofer and its matching tweeter both wired out of phase.
This can produce a thin sound in the lower frequency ranges since you get more cancellation from the out of phase woofers.
A lot of manufacturers use only 1 woofer and 2 tweeters wired out of phase for this very reason. Also I noticed that some surround full dipole speakers are actually adaptive dipole, they just don't advertise it that way.
I believe the term Adaptive dipole was just a catch name given by marketing, who knows.
post #1622 of 1714
thanks for the explanation.
So by doing Rjax suggestion they should sound better?
post #1623 of 1714
I think so. When I converted mine to monopole (bi-pole), I liked the sound better. That is why one guy put in switches so he could easily play around with all the configurations to see what he liked best.
post #1624 of 1714
So the "leads" would be the wires/connectors going to the tweeter that need to be reversed?
post #1625 of 1714
To clarify (or possibly correct?) the RS-300's are not adaptive di-pole speakers. And no, it was not a marketing term conjured up in some brainstorming session. AFAIK, it was first used with the Citation products manufactured by Harmon Kardon. The Citation line was their one and only foray into ubber high end speakers and electronics. They made a surround speaker which truly was an adaptive dipole (and was named as such) and was part of their THX line up of speakers. They simply had numbers. The dipoles were labeled 7.3 THX IIRC. I could go take them off of my wall to be sure, but I think that is correct.
Anyway, they were designed to work hand in hand with the Citation processor so that room sound could be configured and changed with a flip of a switch (either manually with a switch on the speaker) or push of a button on the processor. It would change the surround paramaters from a dispersed dipole to a more direct bi pole sound field. It really was revolutionary and way, WAY ahead of its time.
All of the Citation gear (especially the elctronics - processors and amps), is still highly valued by collectors and audiophiles alike. That gear seems to hold value extremely well and is generally snatched up quickly when it comes up for sale. It really was ahead of the curve when it came out. It's a shame it didn't last.
post #1626 of 1714
I certainly bow to your expertise. I was just giving my best shot with what I knew. The AV123 documents had the term "adaptive Di-polar" in the RSS300 area, so I went with it not knowing any better. I am always learning something new, that is the fun of this hobby.
When set all in phase maybe we can call them "adpative bi-monopolar" ,
Just having fun.
post #1627 of 1714
In doing this, do I have to do an soldering?
post #1628 of 1714
If there is enough "play" in the wire length (there was in my set) you can just cut strip and use wire nuts to reattach the wires, otherwise I would use soldering.
post #1629 of 1714
Thanks for your info & help.
post #1630 of 1714
I did the rephasing of the leads & the speakers now sound more direct instead of softer surround. Something different to get use to.
post #1631 of 1714
I am going to be using 300's for side surrounds and wanted some input on putting them in phase or leaving them as is. Also, does anyone know if there is going to be an inventory clearance or know where I can get another set of 850's? I have a set of 250's in the rear and would really like to replace them with the 850's.
post #1632 of 1714
AV123 is officially closed for good. You can check other forum classifieds to see if or when others are going to get rid of there 850's.
Found a pair for sale over at the emotiva classifieds. http://emotivalounge.proboards.com/i...y&thread=13390
post #1633 of 1714
Did you snip the wires and then criss-cross them and used wire nuts to re-attach or did you resolder the connections?
post #1634 of 1714
Well, it seems that I'm now in need of a RS1000 powered amp. And of course it's the older GSW-350. So, now both original amplifiers that came in my RS1k's have now failed. The one in the left channel failed in May 2005. Now the right channel has failed with the same symptoms (no output, but the power light is on). I see VA321's track record in amplifiers is nothing if not consistent.
post #1635 of 1714
Where's there smoke there's AV123?
post #1636 of 1714
Originally Posted by stereodude View Post
where's there smoke there's av123?
wtf?
post #1637 of 1714
I started out hopeful that it was a bad cap, but that doesn't appear to be the case.
The problem area:
The resistor:
The capacitor:
The cap appears to be fine mechanically (and still seems to holds a charge), just char'd from the resistor failing. Unfortunately, I don't have access to a LCR meter, so I can't definitively test the cap. The resistor on the other hand is completely destroyed and is an open circuit and has burned out completely. There is no hole in the cap where it sat next to the resistor that would indicate the cap vented and cooked the resistor.
I could replace the resistor and cap, but I'm pretty confident something else is wrong with the amp that led it to cook the resistor. So, I'm back to trying to find a replacement.
FWIW, in the first amp failure 5+ years ago there were no obviously cooked components.
The left channel failed amp: (5+ years ago)
post #1638 of 1714
Jeez. I wonder if someone will start a company to strictly service AV123 products.
I guess they'll have to figure out how many units were sold of each series...
1) Rocket
2) X-Series
3) MFWs
Anyone care to estimate?
post #1639 of 1714
I soldered.
post #1640 of 1714
Anyone need some rocket risers???
post #1641 of 1714
Yes, I could use a pair, either for 550 or 750.
post #1642 of 1714
So one of the woofers on my Rocket 550s emits a sort of rattle when driven with loud bass. Does that mean I should replace the driver? If so, where can I find a replacement part?
post #1643 of 1714
Sounds like that is a very good possablility that the driver is bad.
I am getting ready to place an order for a bunch of replacement drivers for various av123 rocket speakers.
I will PM you my email.
post #1644 of 1714
Make sure the woofer's mounting screws are tight.
post #1645 of 1714
I have a nib pair of tweeters for the rss300's if anyone needs them
post #1646 of 1714
No wonder av123 went out of buisness MLS sent you every spare he had for anything you owned
post #1647 of 1714
Lol.
post #1648 of 1714
My Rocket 550/Bigfoot HT is still going strong after many years of high volume servitude!
post #1649 of 1714
Anyone know where to purchase rs-850 woofers? I need to replace one.
post #1650 of 1714
PM sent
  Back to Forum: Speakers
