AVS › AVS Forum › Display Devices › CRT Projectors › Red/blue horizontal shift on BD701s?
post #1 of 3
I was helping a friend setting up his BD701s, and noticed that there was almost not enough range on the red/blue shift in the menu (center square on the convergence menu). On 720P there was just enough range, but when we tried to set up 1080i there was not enoguh shift available.
Are there any internal pots for horizontal shift? I always used the pots on the hor. shift module on my 800/1200 series Barcos to do the coarse adjustments. Then fine tuning in the menu.
Gunnar
post #2 of 3
Anyone have the service manual?
Gunnar
post #3 of 3
Gunnar,
The pictures I found on another site seem to be for a 708 which has them on the 'focus and horiz shift' board.
I have a copy of BD708 diagrams (not a service manual) that indicates the two POTs in the attached picture are for B/R shift. I'm not sure if a 701 is the same, but maybe you can look and see if your friend's has POTs here and look for some identifying lettering.
Mark
  Back to Forum: CRT Projectors
