Does anyone have these mounted to a ceiling mount and if so, are there any modifications that needed to be done? I did find some speaker mounts from Vantage Point and Peerless that will hold bookshelf speakers up to 25 pounds, however, the RTi6's only have one key hole slot behind the speaker. What do you suggest?
