AVS › AVS Forum › Audio › Home Theater In A Box › Using the Onkyo S590 as a component switch
post #1 of 4
I've run out of component inputs on my TV, so I was planning to use the S590 to switch the video lines.
Are there any issues of degrading PQ using it?
I'd be mostly using 480p and sometimes 720p.
Thanks Mike
post #2 of 4
I couldn't tell any difference in running component straight to the TV or through the receiver. I'm sure if you were somehow able to measure the signal strength electronically there would be a difference, because of the extra link in the chain, but to my eyes there was no difference. Some say different, I guess it just has to do with the equipment used and if you get 2" from the TV with a magnafying glass.
post #3 of 4
Anyone else try using the 590 as a component switch?
I still haven't gotten around to getting 3 sets of cables yet....
post #4 of 4
I don't have the 590, but I used the 790 as a switch and then routing direct to the TV. Didn't see a difference, either, at least as far as the signal chain was concerned. I can't imagine the 590 being too different.
  Back to Forum: Home Theater In A Box
