AVS › AVS Forum › Audio › DIY Speakers and Subs › Anything worth doing is worth doing to excess
post #1 of 41
After poking about and stumbling on the Cult of the Infinitely Baffled, messing about with modelling programs like Unibox I have discovered a nice little feature in my home.
I have a natural large subwoofer box which was created when the room over the garage was constructed. Basically a 7500 liter subwoofer cabinet.
Now the IB folks steered me towards the right kind of stuff to generate serious bassness. And here is what I have discovered. Two Ficaraudio Q18 woofers and a Behringer EP2500 amp will provide prodigious amounts of bass. In doing some modelling of both that 7500 liter space and another potential space of 32000 liters, I decided why not put a port into the easily sealed space just to see what might happen. Well, two Q18s in a 7500 liter box tuned to 11.1 hz (the lowest that Unibox will let me tune it, even though I can see a tune just below10 would completely smooth out the curve. Gives me well over 120 dB all the way up and down pumping 400 to 500 watts into each speaker. The same 120 dB when the space is treated as sealed above 25 hz with the standard sealed box rolloff below that. Of course that can easily be picked up with some EQ and room gain. Changing the volume to 32000 liters makes no difference at all for the sealed case. The 32000 could not be sealed off sufficiently to make an even larger tuned box.
So my plan is to build the subwoofer with a port(s) which can be sealed or opened at will. I will have my IB and EBS just like that. This sub will be used up to 40 or 60 hz max depending on matching with the main speakers or most likely by the use of midwoofers.
Two DSP units one for IB and one for EBS would make the job of switching over extremely easy.
How crazy does this sound?
post #2 of 41
I love it loud but I'm danged glad you ain't MY freakin neighbor!
post #3 of 41
I like it!
And you were considering a single Rythmik subwoofer.........
post #4 of 41
Play an 11Hz note through your IB. Then decide if it's worth the bother to have a ported sub with that Fb.
post #5 of 41
Thomas,
Adding the port is a bonus and won't add more than an hour or two to the project. IB is just a matter of clamping the lid is on the port, and switching in the IB tuned DSP. I believe that using a midi cable the DSP can be reset with any EQ "curve" I save on my 'puter. So the one DSP would serve for comparison and a second might be added if I really find I wish to switch back and forth.
I think I have attached the Unibox Plots. Both with 7500 liters, the vented tuned to 11 hz
Power is 400 watts per driver
http://www.digphoto.net/Subwoofer/CBResponseQ18.gif
http://www.digphoto.net/Subwoofer/VBResponseQ18.gif
post #6 of 41
Links are broken.
post #7 of 41
Try again fixed 'em. Not used to posting pics or links here.
post #8 of 41
A bonus?
No not really, infrasonic port tunings that low add nothing to the performance, and porting inherently means worse transient response, and output below the Fb.
BTW, your ported model runs out of Xmax at 15Hz-16Hz. So there isn't going to be any output at 11Hz.
post #9 of 41
Can you afford four 18's ?
Make yourself more future proof because the upgrade demon always visits.
post #10 of 41
Build the IB and watch a few movies before you go mad, you crazy scientist.
post #11 of 41
Excellent idea. Don't listen to the elder scare tactics, you'd gain linearity and headroom. You stand the chance of clipping/bottoming sealed even with two 18"s, this port would all but eliminate any such concerns. The difference in headroom below 20hz is huge. Worrying about transient response in these frequencies is comical - this is the pure room rumbling range. And like you say, you can always stuff it if you don't care for it.
Porting would be great with two 12" diameter ports. ~10" long each for the 11hz tune, ~14" long for 10hz, and ~19.5" long for 9hz. 500 watts per driver would keep you safe, but I'd be inclined to maybe use more because I doubt the max output levels would be approached. And you know, as thylantyr suggested, two more drivers would be even better Like you say, anything worth doing...
post #12 of 41
Steve, I have a semi-comical vision of you playing a 10 second A-B repeat of M&C cannon shots with your head in the way of the 12" diameter ports in your attic.
Martin
post #13 of 41
I know the XMax is reached before 11hz with that model. Sealed runs into XMax problems at 11 hz too.
Unibox has some sort of runtime error below 11 hz tuning. I believe a lower tune would move that maximum excursion lower. It does knock a few dB off too. But nothing like the rolloff with sealed.
post #14 of 41
I'll be polite and simply say the above statement is ********.
When one receives answers to a question it's a good idea to as they say "consider the source."
Here's a question recently posted by the AVS self-appointed ported sub "expert", who can't intuit the answer.....
Here's a somewhat off topic question. Port output is out of phase with the front wave of the driver - in a push pull sealed system, isn't the second driver always out of phase with the first driver's front wave?
Now I repeat my suggestion to play 11Hz from your IB to see if you really think there's any need to have a port at that frequency.
post #15 of 41
His password must have been hacked, because I honestly cannot believe Steve made that statement and asked that question!
I mean.. Wow... Really.
Dr V
post #16 of 41
Thomas tends to attack the person when he can't attack the idea. It's very telling. Yes, I asked a stupid question in that thread, the mention of destructive cancellation from port output at tuning earlier in the thread threw me for a loop.
post #17 of 41
Dr V
Why pick on Steve only. Go back and nitpick every post in this forum and you will find silly claims from everyone. Nonbody is immune to 'Idiocracy'.... BTW,
that movie is great........
post #18 of 41
Jerry,
I like were you are going with this....Whether you go with the sealed (IB) or Ported alignment, I don't think you can wrong. I would agree to start with the simple IB and see if you even will get remotely close to needing the extra headroom down low the ports will bring; I'm gonna be guessing NO, but as you said yourself, you can always add it.
I will suggest exactly what thylantr stated: Do NOT skimp, and go for 4 of the modified Q18s!!! they are a very good bargain, and scott will give a nice little discount when you get 4 of them. WHEN the upgrade bug hits you again, the driver side you will have covered.....get the 4 drivers, and be done with it.
post #19 of 41
Thomas has made some very good suggestions to me steering me toward bass producing components and the wherewithal to utilize those components to good advantage. And an IB is about a simple as it gets with regards to slapping a couple of drivers in a wall or a box. No need to seal the cavity, no messing about with tuning the port. All good things.
Steve is chiming in on the possibilities available when you have a lot of volume for a "box". And I am familiar with the attendant need for more fiddling about.
The shape of the space has even gotten me to thinking about a 10 hz transmission line. The space is a bit over 26 feet behind the mounting wall.
I come from an era when a 30 inch woofer was available in the Patrician line, and I heard a set at a friends home. He had to sell those wonderful speakers when he broke some of his wife's precious china.
post #20 of 41
Try all your ideas and report back. It's not rocket science
The hard part is opening up the wallet for cash, and also taking vitamins to get motivational energy.
post #21 of 41
See Thomas, gets back to my point about ease or simplicity. You validated it for me
post #22 of 41
Discount??? Oh boy I am in real trouble now. I guess I better get busy.
post #23 of 41
This of course has nothing to do with simplicity.
Unlike Steve's tube sub, my large IB can reproduce a pure 10Hz since wave. I make performance measurements using a $5000 calibrated B&K 4133 not a $50 RS meter. So I speak from experience not speculation/assumption.
Originally Posted by HT Nut View Post
]I come from an era when a 30 inch woofer was available in the Patrician line, and I heard a set at a friends home. He had to sell those wonderful speakers when he broke some of his wife's precious china.
Others are equally familar with the EV Patrician, ..... The primary thing going for it was the ability to play loud. It did not, and could not play very low.....
I'm not sure why there's such a big focus on 10Hz. This is the roughly point in the passband where the impedance mismatch between cone drivers and the air they're trying to move, starts significantly impacting the output. As a result, other than the Thigpen rotary sub, the only realistic way to obtain substancial output at 10Hz is with a large number of high Vd drivers. Thinking that a single or dual 18"s in ported or TL alignment will provide a usable amount of output at 10Hz is incorrect.
Before fixating on trying to get ported or LT output at 10Hz, build your IB and play some 10Hz test tones. You'll probably find that chasing this may not be the best idea.
However should you decide this is a goal worth chasing, plan on buying no less than 4-18"s and a Rane PE17. This analog parametric EQ has 10Hz hinge points. If you gange together two filters both with 10Hz hinge points, you'll get boost down to ~8Hz. This is what both Tom Nousaine and I do with our big IB subs. Be aware that doing this puts a significant amount of strain on the structure of the room and anything in it.
post #24 of 41
If I build something that puts significant strain on the structure of the room, there will be an even larger strain on the structure of domestic tranquility.
I am not trying to get to any specific hz or SPL number. I just want to have clean solid bass below 20 hz. And I think that two SSD or Q 18 inch woofers will serve me fine in my home. I would build in an ability to add two additional drivers later. Like after the divorce.
post #25 of 41
Plan ahead is my philosophy (see post above on domestic tranquility). My plan is to "accidentally" step through the ceiling while I'm engaged in worthwhile fixit activity in the attic... I'll think of something. Then, while in the process of "repairing" the nasty hole in the ceiling, I will get an idea!
Honey: "What's an eye bee?"
post #26 of 41
Would this be in line with your excess?
"Size Does Matter! HEMP ACOUSTICS Astonishing New 25" Subwoofer
Finally, due to popular demand, we have decided to launch our Behemoth subwoofer..
We are still deciding on model names. We came up with the following: Kodo (self
explanatory), Tsuzureko pronounced Tsoo'zoo'rako (the worlds largest drum made in
Japan), Behemoth (logical), and perhaps M-39 (hmmm). What do you like? Let us know.
This extraordinary subwoofer is the first model to use one of our new Hempmatrix cones,
specifically created for extremely high output subwoofers: This 25" coned driver is based on
a proven design. With the displacement equal of almost two 18" woofers plus 95 db sensitivity,
an FS of 19hz combined with the ability of being utilized in a 7 cu ft Sealed cabinet or a 12 cu ft Bass
reflex. You end up with one formidable driver. Pricing yet to be determined but will be competitive.
Stay tuned. "
post #27 of 41
I've "accidentally" stepped through the ceiling and it's no fun.
post #28 of 41
Oh yeah, I can just see that big ole box sitting in the driveway when UPS delivers, with HEMP Acoustics on the side. What them boys been smokin'? Hempmatrix cones, stems and seeds?
post #29 of 41
LMAO I love that statement.
I still havent prefected my IB array. Someday I hope I will.
post #30 of 41
I think I have this down pat now.
I have some ceiling work to do from a little AC air handler water damage. And I have to run some HDMI cables to the spare bedroom since cablelabs is holding up MRV on TiVo Series 3 units. Along with rerouting some speaker wiring.
Attic job part of that includes strategic hole poking maneuver after some ruler work..
Lovely wife already complaining about too many boxy looking speakers for HT.
Do a sales job on removing two big ugly black boxes.
Make a mockup woofer holder for the open doorway and try existing woofers in it as a psuedo IB. Just for grins. A couple screws and some duct tape should suffice for a brief test. If it works out, temporarily install present drivers in accidentally prepunched ceiling holes, which are just waiting to be filled with some 18's. (Excuse to keep heat trapped in family room.)
Keep checking email for quotes from Ficaraudio
Find an amp with serious wattage at low impedance and low cost. Probably a futile quest.
Figure out a nice way to camoflage the IB with white. I have a great 12" by 24" grille, but it is way too small for venting four 18 inch woofers.
Go to Home Depot and gather up some flat stuff with which to make structures.
However, I will not succumb to any HEMP.
