AVS › AVS Forum › Display Devices › Screens › How to hookup an electric screen w/ 12V Trigger
post #1 of 2
I would like to know how simple it really is to hook up an electric screen to my amp via a 12v trigger. I ran cable from the front of my room to the back where my amp is located and I have electricity at an outlet near the ceiling.
post #2 of 2
Depends on the screen. Some screen have the interface already wired into the screen. In this case you just run a cable from your device that will supply the trigger current to the screen. You can pick up a cable with a 1/8 plug from Radio Shack which is what most devices use for this. If you have to wire a 12v screen trigger to the screen that's a bit more complicated but not that much more.
  Back to Forum: Screens
