AVS › AVS Forum › Display Devices › Display Calibration › KDF 46e2000 CAlibration?
post #1 of 3
Just wondering, What would the best choice be to calibrate my Sony kdf46e2000 RPTV? I have been searching the forums and I am a little confused to which one to use . I also see that some of these DVD's have versions or have the version year on them . Does this matter? I figure i will get the Avia or DVE . Any thoughts.. Thanks!!
post #2 of 3
bump
post #3 of 3
Have the same TV and used Avia and worked wonderfully. Just to warn you it's not for
daytime use because when your eyes is used to sharp, bright, and vivid picture, Avia's
calibration will be the opposite but not in a bad way.
