i was going to buy an hda2 next week but now ive been coming across threads and posts about the units hdmi to dvi connection not working properly, so now im hesitating. my panasonic ptl 500 has a dvi input so i need the issue resolved. does anyone know if the issue has been fixed?
Featured Stories
hda2 hdmi-dvi issues
AVS Top Picks
post #2 of 77
2/9/07 at 5:14pm
- NovaKane
- Trader Feedback: 0
- IHeartMovies
- offline
- 456 Posts. Joined 1/2007
- Select All Posts By This User
I had the same issue with my SonyXBR 910, but it was resolved with Toshiba's recent firmware update.
If you do end up getting the HD-A2, update the firmware, and your HDMI-DVI handshake still doesn't work, just take the Tosh back (or watch HD through component, as I did before the fix. You just won't be able to upconvert standard DVDs). It's a really great entry level HD-DVD machine.
post #3 of 77
2/10/07 at 4:53am
- PooperScooper
- AVS Moderator
- offline
- 19,251 Posts. Joined 12/2002
post #4 of 77
2/10/07 at 10:40am
- LarryChanin
- offline
- 6,810 Posts. Joined 11/1999
Hi Larry,
If you don't mind my asking, on what are you basing your statement that the firmware update hasn't fixed the PC RGB problem?
Larry
- westgate
- GAZILLIONAIRE!
- offline
- 5,624 Posts. Joined 1/2007
post #6 of 77
2/12/07 at 11:09am
- Jose_L
- offline
- 891 Posts. Joined 1/2001
I've been waiting for some info on whether DVI and the XA2 will work together.
So far I haven't found any ppl. claiming that it would work, so I think all us ppl. w/ DVI connections are out of luck.
You know all this copy protection hurts only consumers who follow the rules. If you rip DVD's and remove the copy protection then you should be able to watch upconverted dvd's thru the component outputs.
Jose
Jose
post #7 of 77
2/12/07 at 11:36am
- LarryChanin
- offline
Jose
Jose
Hi Jose,
As you alude to, the most serious issue regarding HDMI to DVI video connections to displays has to do with the potential to downrezz the image to 480p on some displays. On an AVS survey of HD-A2 owners with HDMI to DVI connections, 43% of those reporting (total of 60) reported problems. I suspect similar statistics would be true for HD-XA2 owners with HDMI to DVI connections, that is, a little over half of the owners would probably not experience this problem.
For example, I have an HD-XA2 player connected to an InFocus projector via HDMI to DVI and do not have downrezzing problems.
As Larry (PooperScooper) mentioned earlier, in addition to downrezzing problems, a problem may also exist with regard to players with HDMI to DVI connections sending incorrect video levels to displays.
Larry
post #8 of 77
2/12/07 at 1:41pm
Originally Posted by LarryChanin
Hi Jose,
Larry
Hi Jose,
Larry
"Downrezzing" may be the most serious, but I'm under the impression it is an especially display specific problem and only represents a small number of people experiencing issues with HDMI->DVI-D. I'm under the impression the most prevalent problem is the crushing of blacks and banding resulting from erroneously extending the luminous range from 16:235 to the full 256 bits.
post #9 of 77
2/12/07 at 5:22pm
- PooperScooper
- AVS Moderator
- offline
If Toshiba had fixed the PC RGB conversion bug with HDMI->DVI I would have thought I'd have seen at least person start a thread and rejoice.
larry
post #10 of 77
2/12/07 at 5:29pm
- PooperScooper
- AVS Moderator
- offline
Very few people with HDMI->DVI are getting correct video from the Tosh's. DVI input displays are surely in the minority by now, which may be one reason the problem is not high priority for Toshiba to fix, if, in fact, it is fixable (or fixable without breaking something else).
larry
post #11 of 77
2/12/07 at 5:53pm
- sharkshark
- No funny shtuff
- offline
- 2,401 Posts. Joined 8/2002
as mentioned elsewhere, I can confirm that on my Sony RPTV the A2 would -not- work at HD res until FW 1.2
The joke was that I bought the player post-FW upgrade, only to be unable to update over the 'net due to, um, being Canadian I guess...
Following the update, everything worked peachy (well, except for Miami Vice barfing, but that's another thread). If the XA2 update actually happens this week, it's likely to help the same issue. I'd wait 'till then to find out...
post #12 of 77
2/12/07 at 6:35pm
- LarryChanin
- offline
larry
larry
Hi Guys,
Please pardon my ignorance. I just want to confirm my understanding that you folks are describing the same issue? That is, because the players connected via HDMI to DVI are incorrectly sending PC RGB levels to the displays, as a result the luminous range is being shifted upward resulting in display miscalibration? Is that essentially correct?
Thanks for the response.
The difficulty with this type of problem is that it can be somewhat subtle and can be confused with display miscalibration. Some folks continue to report "black crush" with HDMI to HDMI connections. Others report the problem as being "solved" by turning the Enhanced Black Level setting ON. Others report the problem as being "solved" by turning it OFF. Others declare "Black Crush" by eyeballing the movies without using calibration discs.
Please correct me if I am wrong, but to definitively determine whether the problem even existed, and now has been resolved, wouldn't someone first need to have a professionally calibrated display, and then special calibration test discs to test for blacker than black and whiter than white, not just test discs used to adjust contrast and brightness?
For example, as I described in an other thread, I have an HDMI to DVI connection to a display that hasn't been professionally calibrated. Using a high definition test signal for adjusting contrast and brightness (available on all European Studio Canal HD DVD releases) I can correctly adjust the black levels, but not the white levels. What does that mean? Do I have a "Black Crush" problem, a "White Crush" problem, a display miscalibration problem, or a combination of one or more problems?
Although I feel that Toshiba has been fairly responsive in coming out with firmware releases, they certainly could be more helpful by describing precisely what the releases are designed to do. If these firmware upgrades are not intended to resolve a "black crush" problem (or whatever the proper term should be), it would be helpful to know that in advance. Their web site is very vague in describing what the upgrade is intended to do. As a result the 30 day return period is running out while people are hoping that a problem will be resolved only to find out, perhaps too late, that it doesn't address the problem.
Larry
post #13 of 77
2/13/07 at 5:05pm
You seem to be interpreting the above HDMI->DVI-D inputs as Toshiba bashing -- it isn't.
There's no reason to spend money on an ISF tech in order to detrmine if there is a problem with delineation of blacks. However, of course, such evaluations cannot be made without taking the time and trouble to perform fundamental black and white level calibration. As far as below black is concerned (0:15), either the player or the display can be incapable of showing that information, and so that is a separate question (and is not inherently related to black crush anyway).
My own HDMI->DVI-D installation does not currently suffer from black crush, but I'm also using the 1.0 firmware release in my G1 player. Based on the experience of others, I have every reason to expect exactly that problem if I install either 1.4 or 2.0. To be sure, I could be wrong given my particular displays, but if I install 2.0 and the problem hits, then I'm stuck because it is not a reversible install.
Even though I don't currently have that problem, I would like to be able to add the newer features, and so I have been following the threads on these issues for some months. It is the experience of others that I'm relaying above, experience I prefer not to bestow upon myself.
PS. If the partial work around you describe above solves your problem, good for you
post #14 of 77
2/13/07 at 9:31pm
- LarryChanin
- offline
.Hi Trevor,
It's not clear to me who you are directing your response. If it was directed to me, I assure you that I did not interpret your responses to be "Toshiba bashing".
In response to my earlier question, was I correct in my statement that your remarks regarding "erroneously extending the luminous range" was essentially the same issue Larry mentioned when he referred to the "PC RGB conversion bug"?
I see a number of forum members loosely using the term "Black Crush" to describe a condition where the shadow details are lost in dark scenes. I am not well versed on this subject, but it seems to me in some instances such a symptom could be merely the result of mis-calibration of the display, a mis-calibration of the player, or a combination of both, and not necessarily a flaw in either device.
Sometimes the factory "neutral" settings of players may yield a darker picture than the owner is accustomed to seeing on their other DVD players and cable or satellite receivers. As a consequence, they may jump to the conclusion that they have a "Black Crush" problem with their new HD DVD player. When I first starting using my HD-XA2 I also felt the picture looked a bit darker than I am used to. However, I also noticed that images on HDMI to DVI were darker than on component video. This suggested to me that perhaps there was a problem with the player on HDMI to DVI.
Fortunately, the HD-XA2 player has picture control adjustments that permit performing black and white level calibration of the player without resorting to recalibrating the display and throwing off the calibration for my other source devices. As you are probably aware the HD-XA2 has three sets of user-defined picture settings. In the interim, until it is determined whether there is a colorspace problem with these players on HDMI to DVI, and an upcoming firmware fix, I have been able to calibrate the player using these three settings.
Using the high definition video test signal available on the Studio Canal discs, I calibrated black and white levels for HD DVD on the HDMI to DVI connection using the first set of user settings. I also calibrated black and white levels for HD DVD on component video using the second set of user settings. And finally using the standard definition Avia DVD, I calibrated black and white levels for standard upconverted DVDs on the HDMI to DVI connection using the third set of user settings. Needless to say all three settings are different.
Doing this I find that I can properly set black levels. So it would appear that I do not have a "Black Crush" problem that can't be overcome by calibration of the player. With regard to white levels, I can decrease the contrast so that I can barely make out a line delineating each of the 16 gray scale blocks on the high definition video test signal, but at the whitest two blocks look like they are the same level. I have a very bright DLP projector, and perhaps it has reached it's maximum contrast and that is all that I can reasonably expect regardless of my player. Nevertheless, I find the HD images from the player to be extremely high quality and as good as, if not better, than anything I have seen on HD satellite. I haven't really studied the upscaling, but it appears to be at least as good as my Bravo D2 upconverting DVD player.
Larry
post #15 of 77
2/14/07 at 7:06am
- giomania
- SubMersed in bass
- offline
- 2,636 Posts. Joined 11/2001
post #16 of 77
2/14/07 at 1:22pm
- billymac
- offline
- 2,282 Posts. Joined 8/2004
larry, i'm no expert, but i do know what i see and i can tell you that calibrating my display does not get me better blacks or shadow detail. the issue is that the tosh is sending PC RGB levels, but my display thinks it's seeing REC709. it is not REC709. and no offense, but it's so tiring hearing others say to simply calibrate for the source. that's great, but the bottom line is the signal and information being sent is not complete. i'm not simply talking about btb and wtw, i'm talking about missing information. something you can not get back. i don't know if you've been reading any of the hdmi switching receiver threads, but there are models out that are essentially doing similar things while transcoding and upscaling over hmdi.
i can confirm this by sending hdmi through a M1-hdmi adapter on another input. with that i can select RGB and Video RGB. when selecting RGB the picture is GREAT! one catch, i can only get 480p. it's totally lame.
the whole thing is absolutely ridiculous in my opinion. trust me, the picture REALLY is that bad under these conditions. it's not an issue of simply calibrating for the source. it has everything to do with the stupid hdcp handshake, edid and the player misinterpeting the display device.
and pooper, you're crazy if you don't think there are a TON of dvi displays still out there. this problem is going to get worse before it gets better imo.
toshiba should be able to fix all of this by simply letting you select the colorspace output at the player level. why is that so difficult? is it a limitation of hdcp? oh my god, here comes hdmi 1.4. sigh. i'm sorry to sound so frustrated and like a cry baby but i've spent so much time trying to get this to work, it's really sad. if you take a look at the pole that someone started about people having issues with 2.0 firmware you'll see it isn't just a few people. be sure and add those with video and those with both video AND audio. imo, those numbers aren't something to overlook or blow off.
post #17 of 77
2/14/07 at 5:57pm
- PooperScooper
- AVS Moderator
- offline
billymac,
There are a lot DVI displays, but there are more HDMI displays. That's all I meant. I have a DVI display.
However component output works fine from my A1. I don't recall people talking about the rec709 vs rec601 issue. With the DVI output problem I don't see how one could tell.
At this point I really don't care because sometime soon I'll be getting a video processor with HDMI input and I won't have to worry.
larry
At this point I really don't care because sometime soon I'll be getting a video processor with HDMI input and I won't have to worry.larry
post #18 of 77
2/14/07 at 6:00pm
- LarryChanin
- offline
Hi Billy,
My projector, An InFocus ScreenPlay 7205, allows some adjustments to colorspace. Here's an excerpt from the manual:
Color Space: This option applies to computer and HDTV sources (it won't appear in the menu for video sources). It allows you to select a color space that has been specifically tuned for the video input. When Auto is selected, the projector automatically determines the standard. To choose a different setting, turn off Auto, then choose RGB for computer sources, choose REC709 for component 1080i or 720p sources, or choose REC601 for component 480p or 576p sources.
My projector is currently in the default setting of Auto. Do you suppose it's possible that it is already selecting the processing standard appropriate to the signal it is receiving? Or do you think I should select RGB for the HDMI to DVI input? Or none of the above?
Larry
post #19 of 77
2/14/07 at 6:43pm
- billymac
- offline
larry
i own an in72 and in76 so i'm familiar with the colorspace options on your infocus. you can uncheck auto and then choose rgb or rgb video however i believe you'll find that you get a green cast on the image. or, you may only be able to get 480p or 720p. i believe hihostevo owns either a 7205 or a 7210 and has issues where he can only get 720p out of his A1 over the m1 input.
there's an option on the INXX series that enables you to turn on and turn off DDC which basically has something to do with the hdcp handshake and edid. disabling DDC on the HDMI and M1 ports allows me to select RGB colorspace on the infocus but all i can get is 480p. selecting anything else locks up my player and i've tried everything. it's a great example though of what the picture "should" look like, so i know i'm not dreaming all this up.
i wish i could speak more technically about what is going on with the colorspace issue, and maybe pooper or someone else can help me out here, but essentially when the player sees certain dvi displays, it not only incorrectly sends the wrong color space, but information from the source signal is lost in the process.
i do not know if the 7205 firmware has the DDC option but you may want to play with it. it may allow you to disable DDC. what's funny about DDC is, when i disable it i am unable to select either of the REC's only RGB and RGB video.
post #20 of 77
2/15/07 at 10:33am
- LarryChanin
- offline
larry
larry
Hi Billy,
Thanks for your interest and suggestions.
When I get a chance, maybe I'll try the PC RGB colorspace options.
I did a quick read of hihostevo's thread discussing his problem. As I understand it even though his projector is native 720p he would prefer to output 1080i from the player because most owners of HD-A1's feel the picture looks better. In my case using an HD-XA2, if I was forced to decide which output resolution is better, I'd say the 720p provided the better picture. (However, since it takes some time to go through the menus to reset the resolution, it is somewhat difficult to make "scientific" comparisons without switching resolution instantaneously. Frankly both look good to me.)
Anyway, the point is Steve's problems seem to be unrelated to HDMI to DVI colorspace issues, but rather handshake issues, and passing display data. Steve's difficulties with passing display information appear only to effect the setting of resolution on the Toshiba player. Since I like the 720p resolution I don't see that as a problem. Even if I did prefer 1080i, I doubt changing to this output resolution would have any bearing on correcting color space problem.
My projector does not have a user accessible option to turn off the DDC feature.
Larry
post #21 of 77
2/15/07 at 12:29pm
- billymac
- offline
post #22 of 77
2/15/07 at 1:19pm
- LarryChanin
- offline
Hi Billy,
I have to admit most of this stuff is over my head, but I did try to do some basic research on the subject.
I gather that there is a copy protection portion of the handshake (High-bandwidth Digital Content Protection or HDCP) to prevent copying HD digital content. Sometimes when there are incompatibilities between devices, either the image will not be transmitted to the display at all, or the player will be instructed to down rez the content to 480.
I doubt that Steve and I are having problems with this portion of the handshake because we are both receiving an image and it is not being down rezzed to 480.
The other portion of the handshake has to do with exchanging display information between the display and the player via Display Data Channel (DDC). As I understand it, this display data (Extended Display Identification Data or EDID) resides on an EDID ROM chip in the display device. It contains the following information.
- Manufacturer Name
- Product Type
- Supported Video Resolutions
- Supported Audio Formats
- Color Depth Capabilities
The purpose of exchanging this information is to permit a source device to automatically adjust the video and audio output to the best possible format for the display device.
Although Steve's projector is native 720p, it will accept 1080i. In Steve's problem somehow this exchange of display data does not recognize that his projector will accept 1080i.
It has been suggested that the color space problem with the second generation Toshiba players via HDMI to DVI is due to the player incorrectly sending PC RGB levels to the display instead of Studio Video level (sRGB). Are you saying that somehow Toshiba's implementation of the HDMI to DVI connection via DDC is telling the player to send PC RGB color space levels instead of Studio Video levels, because it is incorrectly reading the characteristics of the display?
The fundamental problem with this seems to be that even if DDC is the root cause in both situations, turning it off seems to invoke HDCP handshake problems which are even more objectionable, i.e., down rezzing or loss of signal.
Larry
post #23 of 77
2/15/07 at 2:39pm
- billymac
- offline
yes. that's exactly what i'm saying.
yes, but i'm able to turn off DDC for M1 on the display, use an M1:hdmi adatper, select RGB on the display and i get all my black and shadow detail back--in 480p.
i think you may be right about DDC on the hdmi port. i think maybe that didn't work. but i was able to get it to work on the M1 with it off.
post #24 of 77
2/16/07 at 4:04am
- PooperScooper
- AVS Moderator
- offline
post #25 of 77
2/16/07 at 7:06am
- billymac
- offline
post #26 of 77
2/16/07 at 7:52am
- LarryChanin
- offline
Hi Larry,
I mean both.
If the HDCP handshake thinks the HDMI to DVI connection is not HDCP-enabled, the HD copy protection features cause it to automatically adjust the player's output resolution to standard definition on the HDMI output. However, since the second generation Toshiba players permit simultaneous output of video on its HDMI and component video ports, it will also change the output resolution on the component video to standard definition. As a result, an HDMI to DVI incompatibility effects both the high definition and upscaling functions of the player.
Even if there are no HDMI incompatibilities, if a standard disc is copy protected, the output on the component video port will be down rezzed to standard definition, regardless of whether a good HDMI (HDCP-enabled) connection is detected on the HDMI port.
Larry
post #27 of 77
2/16/07 at 9:09am
- giomania
- SubMersed in bass
- offline
Larry
Larry
Larry, Carl Sundbom performed a great deal of research on white and black crush for the Pioneer DV-59avi using a Lumagen VisionHDP scaler IRE readout feature. See below for the details. At the time, he had a display with a DVI input. I hope this helps explain some things. I wonder if Carl has a HD Player...of either format?
Settings to Avoid White and Black Crush on a Pioneer DV-59avi
The player suffers from white crush over HDMI in the default setting. All white information over 235 gets discarded. I've been measuring the HDMI port data, and found one, and only one, setting where the player behaves like it should. That is, outputting reference HDMI-Video levels, no black crush, no white crush and no compression of the signal range.
In the Video Adjust menu:
White Level: All the way to the left (min setting)
Black Level: One notch down from center settings (towards min)
Black Setup: 7.5 IRE
HDMI Color Adjust: Enhanced
All other settings as default for the "HDMI Direct" preset.
Settings for HDMI output were tested for RGB only. Don't know how YCbCr is handled over HDMI.
Carl Sundbom
Additional HDMI settings for a Pioneer DV-59avi:
I did some work tonight, and these are my findings.
Tools:
Firmware revision of DVD Player: 1.526
Test patterns: Avia Pro IRE window patterns (from 2.5 IRE to 108.5 IRE)
Video black defined as 7.5 IRE, nominal white as 100 IRE, peak white 108.5 IRE.
Represents DVD content luma values from 6 to 254.
Data analyzer: Lumagen VisionHDP scaler IRE readout feature
Standard vs. Enhanced "HDMI Color Adjust": The "Standard" mode prevents output of any values lower than 16 or higher than 235 over the HDMI port. Assuming we are trying to output what's on the DVD, the only way to make this happen in "Standard" mode is to compress the dynamic range from 1-254 to 16-235 by using the black/white level controls to cram the BtB and WtW content into the 16-235 range. Not recommended, since we will lose fidelity. You will be able to see BtB and WtW if you do this, but you will lose grayscale steps in the middle.
"Enhanced" mode will allow us to output any value from 1-254. Now we just need to map the video black to 16 and nominal white to 235 (still preserving the WtW content up to 254). Since my testing concluded that we need "Enhanced" HDMI Color Adjust to get us in the ballpark, let's look at the other settings.
There is an interaction between the "Black Level" control and the "IRE Set up" control. You can achieve almost the same results by leaving "IRE Set up" at 0, and compensate by raising the "Black Level" control as you can be setting "IRE Set up" to 7.5. However, it's not perfect, and black will end up being a little off from its standard value (a little higher or lower than 16, depending on "Black Level" setting). Setting "IRE Set up" to 7.5 and lowering the black level one notch gets us to perfect video black (luma 16 over HDMI). This will also preserve most of the BtB content (80-90% in my estimation).
The "White Level" control in its default setting will re-sample all content over 235 to whatever the maximum value is. For "Standard", this will be 235, so everything over 235 will be output as 235. For "Enhanced" this will be 254, so everything over 235 will be output as 254. This will also "stretch" the rest of the grayscale, so all values will be too high. Lowering the "White Level" to it's leftmost position will preserve all the steps between 235 and 254. The "stretching" of the grayscale is also avoided to a large degree.
The settings I ended up with are the same as the ones I listed earlier. They are as close as I could get, but they're not perfect. There is still a slight "stretch". A value of 6 on the DVD would be output as 5 or 4, and a value of 251 on the DVD would be output as 254. There is clearly some re-sampling going on, no matter what settings are used. I doubt this will have any real effects watching a movie. An SDI mod may be the only way to get the 59-Avi to output a pristine "DVD perfect" signal, but from what I've seen so far, this is one heck of a player
A couple of more points of clarification.
1. The 'HDMI Color Adjust' defines the output range. Standard is 16-235 and Enhanced is 1-254. I think this control is a misguided attempt at implementing Video vs PC levels. "Standard" set video black at 16, and nominal white at 235, alright, but it compresses all BtB data into 16 and all WtW data into 235. Since the whole point of running Video instead of PC levels is to pass BtB and WtW, this is clearly a design flaw.
2. The black level control defines the value of black. This should be 16 over HDMI. It doesn't operate like a normal brightness control, which would move the entire video range up and down. Moving it up only compresses values in the midrange. Nominal white doesn't move when you increase black level.
3. The white level control should be renamed to "white crush control". All it does is define what values should be output with the maximum luma value. By default, it defines everything from 235 to 254 to be 254 (in Enhanced mode). Rasing the white level control pulls even more values in to be 254. It also "pulls" the rest of the range with it, increasing the difference between between the mid grays. So how much white crush do you want? Now you have a choice!
Carl Sundbom
Carl Sundbom
Tools:
Carl Sundbom
Please note the above is for the Pioneer DV-59avi, not the Toshiba HD-DVD Player. I posted it because Larry was asking how to determine if there is a problem, and this provides an explanation of one way to research it.
Mark
post #28 of 77
2/16/07 at 10:08am
- LarryChanin
- offline
Mark
Mark
Hi Mark,
Thanks very much for the response.
Needless to say, I'm looking for a less expensive approach that doesn't involve purchasing a Lumagen VisionHDP scaler with IRE readout feature ($2,500) and a copy of Avia Pro ($400).
I believe that the consumer version of the Digital Video Essential disc has blacker than black tests, and perhap Whiter than White as well. Hopefully the consumer version of the high definition Video Essentials, which is expected to be released this month, will have them.
Just a note to others following this thread, the Pioneer DV-59avi's problems, which prevents it from passing Blacker than Black or Peak White data, (i.e. luminance data below 16 or above 235) is not related to a HDMI to DVI problem as in the case of the Toshibas.
One thing (among many
) that I'm not clear on is does sending incorrect color space levels (PC RGB) to the display, automatically mean there must be blacker than black or whiter than white problems?Larry
post #29 of 77
2/16/07 at 10:51am
- giomania
- SubMersed in bass
- offline
I know, but I am hoping that Carl can perform the same service if he has the Toshiba players and still has his DVI display. I sent him a PM notifying him of the thread, so maybe he can chime in.
Excellent point, lest anyone think otherwise.
) that I'm not clear on is does sending incorrect color space levels (PC RGB) to the display, automatically mean there must be blacker than black or whiter than white problems?Is it not the case that BTB and WTW does not exist on PC RGB levels? I know it seems counter-intuitive, as the PC RGB range (0-255) is greater than the YCbCr (16-235) range. My memory is not working well today. Hopefully Carl will chime in when he gets the PM.
Mark
post #30 of 77
2/16/07 at 11:11am
- LarryChanin
- offline
Hi Mark,
Pardon a guess. Its not that BTB and WTW levels don't exist in PC RGB color space, its just that that if the player is supposed to send Studio Video levels in the 16-235 range and converts it to PC RGB to the the 0-255 range, it is erroneously shifting where true black (16) or true white (235) should be. With the player's factory "neutral" setting I believe the shifting is causing black to clip, "crush". The question is can these shifted levels be shifted back to correct value by simply using the CONTRAST and BRIGHTNESS controls on the player? From my observations, it would appear, based on test video signals, that I can get black levels correct and white levels almost correct. Obviously the player settings are significantly different from the factory "neutral" settings. With a player without a color space problem I would expect a properly calibrated player would have setting close to the factory "neutral" settings.
Larry
Back to Forum: HD DVD Players
- hda2 hdmi-dvi issues
AVS Top Picks
Currently, there are 1428 Active Users
(212 Members and 1216 Guests)
Recent Discussions
- › Defiance 6 seconds ago
- › NE Spring Speaker Shootout results thread - April 13, 2013 29 seconds ago
- › JL Audio Fathom 13" Sub 1 minute ago
- › The SKYFALL Theatre 1 minute ago
- › Help needed connecting a Samsung DVD Player to a Yamaha RX-V457 1 minute ago
- › Panasonic TC-65PS64 and TC-50PS64 ~OWNER'S POLL~ 2 minutes ago
- › Revel Owners Thread 2 minutes ago
- › The 'Official' 2013 Denon "E Series" / "X Series" AVR Model Owner's... 2 minutes ago
- › Microsoft fires the first shot in the "NEXT" generation.... 3 minutes ago
- › The Offical Epson 8350 Owners Thread 3 minutes ago
View: New Posts | All Discussions
Recent Reviews
- › Sony BRAVIA KDL55HX850 55-Inch LED HDTV by Falgoonit
- › Marantz AV8801 by zuluwalker
- › VIZIO 55 inch Class LED - M3D550KDE by indept
- › Optoma GT700 3D Game Time Projector by paul65000
- › InFocus X1A DLP Multimedia Video Projector by coastercard
- › BenQ W1070 1080P 3D Projector by arjjr
- › Epson PowerLite Home Cinema 8350 by Natros
- › Epson V11H501020 PowerLite Home Cinema 3020 2D and 3D 1080p Home... by sailorb
- › Elite Screens ER110WH1 Sable Fixed Frame (110" 16:9 AR) by DDT0C
- › Elite Screens ER100WH1-A1080P2 Sable Fixed Frame Projection Screen by DDT0C
View: More Reviews
New Articles
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
- › Clarus Power Cords by Good Tunes
- › A Theater Is Just Is Not A Theater, Unless... by David Bott
View: New Articles | All Articles
Home | Reviews | Forums | Articles | My Profile
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
