The following is the new Sceptre 42" lcd that will be on sale at Costco on 3/5.
X42GV-Komodo HDTV LCD
Ultra Slim Speaker Design
42" 16:9 HDTV LCD Speaker 10 Watts per Channel
Fully HD Compatible Response Time 6ms
Support 1080p Video Contrast 2000:1
Built-in NTSC, ATSC & QAM Tuner
DETAILED SPECIFICATIONS :
LCD Panel
42" viewable wide color LCD TV
Aspect Ratio 16:9 Wide Screen
Brightness 500 cd/m2
Contrast 2000:1
Response Time 6 ms
Viewing Angle 178 L/R, 178 u/d
Backlight Lamp life > 50,000 hrs
Video Functions
De-interlace - 3D, Faroudja DCDi
Frame recover 3:2
Noise reducing core technology : 3D,
Cross Color Suppression
Aspect ratio : 16:9 Wide, 16:9 Normal, 4:3
Wide, 4:3 Normal, 4:3 Zoom
Gamma Fixed Gamma
Lamp adjustment
Picture mode : Custom / Standard / Mild / Vivid /
Multimedia / Recall
Video adjustment : Contrast / Brightness /
Sharpness / Saturation / Tint / RGB
Color temp. adjust : Cool / Normal / Warm
Picture Enhancement : ACC (Adaptive Contrast
Ratio), ACM (Active Color Management),
Faroudja True Image Enhancement
PIP/POP Yes
Audio functions
Output (RMS): 2 x 10w
Sound Enhancement: Digital Signal Processing
SRS TrueSurround XT
Built-in speakers: 4 x 10 watts per Channel
Connections Port
Hybrid TV Tuner NTSC, ATSC & QAM Tuner
AV 1 (CVBS), Audio L/R in
AV 2 (CVBS), Audio L/R in
AV 3 (S-Video), Audio shared with AV2
YPbPr1, Audio L/R in & YPbPr2, Audio L/R in
HDMI 1 & HDMI 2
VGA, Stereo in
Side Connections: Audio L/R in, AV2 (CVBS) in,
AV3 (S-video) In
Other Connections: AUX OUT (CVBS out, Audio L/R
out), S/PDIF out (optical)
Compatibility Signals
Color System NTSC (US), ATSC & QAM
Coaxial input support:
- Digital (ATSC) and Analog (NTSC) TV
in air
- Digital and analog TV in cable
(unscripted signal only) QAM
Component input support: 1080P, 1080i, 720P,
480P and 480i video signal
HDMI input support :
- 1080P,1080i, 720P, 480P,480i video
signal
- HDCP video up to 1080P
- DVI signal from PC, max. resolution
1920X1080, native resolution 1360X768
Control Functions
Digital TV & Analog channel
Channel return, Favorite Channel
Closed Caption
Channel auto scan
Sleep timer : Off /15mins /30mins /60mins
/90mins /120mins
V-Chip
Picture setting / Sound setting / Program Guide
Regulation
CSA, CSA-US, FCC Class B
Sizes & Power
Wall Mount Bracket (optional)
: Height 100mm x Width 200mm
LCD Dimension :
40.5(W) x 27.31(H) x 9(D) inch with Base
40.5(W) x 25.5(H) x 4.5(D) inch w/o Base
Net Weight : 61.6lbs Gross Weight : 79lbs
Power Source Input : 100-240AVC, 50/60Hz,
3.5A max
LCD Panel
Contrast 2000:1
Response Time 6 ms
Video Functions
Frame recover 3:2
Gamma Fixed Gamma
Lamp adjustment
Multimedia / Recall
PIP/POP Yes
Audio functions
SRS TrueSurround XT
Connections Port
HDMI 1 & HDMI 2
VGA, Stereo in
AV3 (S-video) In
in air
signal
Control Functions
Closed Caption
Channel auto scan
/90mins /120mins
V-Chip
Regulation
Sizes & Power
LCD Dimension :
3.5A max
