AVS › AVS Forum › HDTV › HDTV Technical › Summary of DTV Tuners w/ (standard) DVD Recorders
post #1 of 129
The updated list is kept at:
http://en.wikipedia.org/wiki/DVD_rec..._DVD_recorders
I posted this over in the DVD recorder forum, but I thought I'd break the rules and post over here also: http://www.avsforum.com/avs-vb/showthread.php?t=791417
LG DR787T - 230 - Now - Does not output native HD - Forum thread - Review
LG DR797T - VHS - 300 - Now - Does not output native HD - Forum thread
Panasonic DMR-EZ7K - April - Up convert to 1080p - Alternate
Panasonic DMR-EZ17K - QAM - 200 - Now - Manual
Panasonic DMR-EZ37K - QAM - VHS - 315 - March
Philips DVDR3505 - 200 - Now - Up converts to 720p and 1080i - User Manual - Alt 1 2
Philips DVDR3575H_37 - 160GB Hard Disc - 330 - April - 1080p
RCA DRC8335 VHS 250 - April
Samsung AVR650 250 - April
Samsung AVR950 - VHS - 300 - April
Sylvania zc350sl8 - 170 - April
Toshiba D-R550 - QAM - 230 - March - Alt 1 Alt 2 3
Toshiba D-VR650 - QAM - VHS - 275 - March
I put a March date on the units that were available for preorder in February.
All have a DVD recorder so far.
post #2 of 129
Considering folks could use such a device just as a digital tuner, they definitely belong here.
post #3 of 129
The panny EZ17 for $200.. that's not a bad deal at all.
post #4 of 129
Not one has a QAM tuner.
post #5 of 129
The Panasonic recorders have QAM.
Ron
post #6 of 129
Not according to those two links.
post #7 of 129
No one knows for sure - just because it's not listed in the specs doesn't mean it doesn't have a QAM tuner.
post #8 of 129
hopefully the introduction of all these recorders in the $150-300 range will push down the price of DTV set top boxes currently going for $150-200.
post #9 of 129
I do know for sure on the Panasonic recorders. Although I'm not directly on the design team (I did help to build a suite of test ATSC bitstreams for the decoder engineers), they sit across the hall from me.
For those keeping track, the demodulator chip is the ATI (AMD) Theater 312.
http://ati.amd.com/products/theater314/index.html
Ron
post #10 of 129
Ron
When do you think they will be available? Why do you suppose these companies wait till the last minute to make these products available? In other words why didn't they make them available for sale last month?
Just wondering,
Daniel
post #11 of 129
Just wondering,
Daniel
The DMR-EZ17 should be available very soon.
Ron
post #12 of 129
They will not make them available even one day early, and will not publically foreshadow their availability, because to do otherwise would render their vendor's and their own remaining inventory of NTSC-only products virtually worthless.
post #13 of 129
I do know for sure on the Panasonic recorders. .... For those keeping track, the demodulator chip is the ATI (AMD) Theater 312.
Is that the same chip as what's in the Samsung H260F? If not, is it still a fifth-gen-performance chip?
post #14 of 129
Originally Posted by AntAltMike View Post
They will not make them available even one day early, and will not publically foreshadow their availability, because to do otherwise would render their vendor's and their own remaining inventory of NYSC-only products virtually worthless.
that's assuming that their vendors don't know of the product pipeline - a risky assumption.
why do you think the Samsung 260F is so hard to come by at CC/BB?
post #15 of 129
Originally Posted by ReplayJanitor View Post
But, they may not do so, since the recorders don't output HD.
And you know this because .....
post #16 of 129
Ron
Sounds like that chip can do QAM.
post #17 of 129
I went ahead and edited that statement out of my post. Some of the ATSC recorders can upconvert DVDs to HD, so I guess that means HD output.
I have a technical question. Assuming a device outputs video through component (nevermind HDMI or DVI for now)... Does it cost more (processing power) to decode and output HD 720p/1080i than it does to decode HD, downconvert and output 480p/480i?
post #18 of 129
Can, but will it??
post #19 of 129
Probably not, it's all done with one chip - which has multiple outputs.
post #20 of 129
Can, but will it??
Won't know till someone tests it. And even after someone says it does, there's always a ..... BUT
post #21 of 129
These look great. However I had a couple of thoughts. I didn't see any that would record in HD via Blu-ray of some such. Also do any have firewire or any other ability to record anything but OTA?
Rick R
post #22 of 129
Unfortunately, these products are still a ways off for the U.S. market.
None of the products announced so far can record in high-def. They run all programming through a NTSC encoder.
Cable compatibility brings CableLabs into the mix, and some manufacturers don't want to open that can of worms.
post #23 of 129
post #24 of 129
By this I assume you mean that they are making standard DVDs. Thus 480i x 720. So I guess this is still better than VHS and it is anamorphic widescreen.
Rick R
post #25 of 129
Yes.
What I would like to see are products that save content to the hard drive in high-definition, allow playback in high-definition, but that use a NTSC encoder when saving to DVD. To my knowledge, no such products are yet announced for the U.S. market.
post #26 of 129
Yes.
, but that use a NTSC encoder when saving to DVD. .
again why would any recorder need to do anything (NTSC encoding) with an MPEG stream (incoming ATSC or QAM) when it will end up in MPEG on the DVD?
The only time NTSC is involved is at the SD output, no?
post #27 of 129
Eh? ATSC is up to 19.4Mbps, almost twice what is supported by the DVD specification. The DVD specification is also limited to MP@ML decoding, so you can't store MP@HL content o the disk.
Once the [up to] 19.4Mbps ATSC signal is run through the MPEG-2 decoder, it is no longer MPEG-2. It is an uncompressed video signal. You can't stick an uncompressed video signal on a DVD in any format; it's got to be recompressed using MPEG-2, and there's what there NTSC encoder comes in.
post #28 of 129
Why couldn't the incoming MPEG2 stream be transcoded directly to an MPEG2 stream the DVDr recorder can handle? I assumed the whole point was to keep everything in 1s and 0s format and not lose PQ along the way (by decoding/encoding).
post #29 of 129
480p would be 19.4 Mbps?
post #30 of 129
The signal remains digital, of course. But you can't get from 12-19Mbps 720p/1080i MPEG-2 to <10Mbps 480p MPEG-2 without re-encoding. In this case, the re-encoding is performed by a MP@ML MPEG-2 encoder, which is also used to encode an NTSC (CCIR-656) input.
I think there may be some confusion from the term "NTSC encoder." I am not referring to a part that encodes digital video into analog NTSC format. I'm referring to parts that accept NTSC video input (i.e. CCIR-656) and encode it into 480i digital.
These are just new versions of past DVD recorder products with the ability to take a ATSC source as input.
ATSC defines 19.4Mbps, yes, although the original broadcast format is rarely 480p. It is typically 720p (FOX, ABC) and 1080i (CBS, NBC, PBS). In contrast, DVD defines a maximum of 10.04 Mbps.
  Back to Forum: HDTV Technical
