AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Yamaha htr 5960 ,where are the test tones????
post #1 of 4
My neighbor purchased a new htr 5960 and for some reason we can't find the test tone function on the remote or in the avr menu,
I have a htr 5790 and it it very different from the 5960 so if any of you guys have one can you please tell me how to set up with the test tones.
post #2 of 4
http://www.yamaha.ca/av/PDFs/Receive...HTR5960_en.pdf
check on page 86 or 90 "SET MENU" chapter , 1. Sound Menu - Speaker settings A)SPEAKER SET
Use this feature to manually adjust any speaker settings.
Speaker level B)SPEAKER LEVEL
Use this feature to manually balance the speaker levels
between the front left or surround left speakers and each
speaker selected in SPEAKER SET (see page 86).
Control range: -10.0 to +10.0 dB
Control step: 0.5 dB
Initial setting: 0 dB
post #3 of 4
I was looking for a way to use the test tones without going into the menus.
post #4 of 4
Page 42 or 46 of the Manual
Adjusting the speaker level
You can adjust the output level of each speaker while
listening to a music source. This is also possible when
playing sources input at the MULTI CH INPUT jacks.
Note
This operation will override the level adjustments made in
AUTO SETUP (see page 32) and SPEAKER LEVEL (see
page 89).
This operation can also be performed using the control buttons on
the front panel. Press NEXT on the front panel repeatedly to
select the speaker channel whose output level you want to adjust
and then press LEVEL +/- on the front panel to adjust the output
level.
1 Set the component selector switch to AMP
and then press LEVEL on the remote control
repeatedly to select the speaker you want to
adjust.
2 Press j / i on the remote control to adjust the
speaker output level.
Press i to increase the value.
Press j to decrease the value.
Control range: -10 dB to +10 dB
3 Press ENTER on the remote control when
you have completed your adjustment.
