I need you the experts help. I am new to the HDTV world (coming from sd crt set) but have read up alot on the different options. I have concluded that an RPT is the best option in terms of price/value. But now cannot decide between the Mitsubishi DLP and the Sony A2000.
I was all set to get the A2000 when I saw it in Frys. In the harsh lighting of Frys and next to the XBR and mitsubishi the A2000 looked terrible - kinda hazy and dim. The salesman attributed this to the weaker bulb and the video processing. And really pushed the new mitsubishi 831 and 731 models. What are your opinions between the two? Was it just a lemon A2000 that I saw on the floor?
Also he indicated that the only real difference between the 731 and 831 is that the 731 does not have memory card readers. Is there any other key differences? The 56 inch 731 that they had was a great deal. Thanks for the help.
). Both set will burn you eyeballs at default settings in a dark room so don't worry about the Sony being dim. Blacks are better on the A2000 but 732 wasn't bad at all. If you aren't bothered by RBE then I personally would choose the Mits but, not 731... atleast the 732 due to available PerfectTint.
