AVS › AVS Forum › Video Components › Home Theater Computers › HTPC - Mac Chat › Exporting HD Content with eyeTV
post #1 of 4
Help. I'm having trouble exporting HD content with eyeTV and my 500. No matter what settings I choose, my programs (a) look like crap and (b) are always some sort of 4:3 letterboxed monstrosity. Can anyone recommend decent settings to use? I'd like to export so that I can play back on my G4 mini, so at best I'm looking for something in a 720p although a 480p is preferable. I don't currently own the divx encoder, but I'm willing to purchase if it will do a decent job.
post #2 of 4
Andrew67 - If you have a G4 mini - you probably don't want HD - I don't believe it will playback at the right framerate. In my crazy rant below - you may just want 720x405 size settings for letterboxed material - and 720x540 for 4:3 material.
Below is my current workflow for creating 720p H.264 w/ 5.1 AAC files. 42 Minutes ( 1 hour of HDTV television ) is around 1 GB for 1080i @ 30 fps ( down-rez'ed to 720p)// 1.3 GB's for 720p @ 59.94 fps
There is 2 versions - Simple and Complex. Simple is stereo audio - Complex is the 5.1 AAC. Both will create a .mov. This is a work in progress for me - Wanted to post and exchange info. Looked like a good thread to start on.
- Download and install x264 encoder ( faster h.264 encodings - nice quality at 1-pass - Could try 2 pass if not good enough for you)
http://www.macupdate.com/info.php/id/20273
You can choose this encoder from quicktime - make a quicktime mov and choose x264.
SIMPLE - Stereo Audio
1.) Edit then export from EyeTV - Create QUICKTIME movie -
2.) Click options
3.) Under Video - SETTINGS - Select x264 \\ 1-pass \\ Frame rate = Current \\ if source is 1080i Restrict bitrate = 3000kbps - if 720p = 1800kbps \\
4.) Under SIZE - 720p setting ( 1280x720 ) - I pick this because my display is 720p
5.) Under Sound - AAC stereo 128
COMPLEX - but retains 5.1 surround.
( tough call on what to do here - but I am sticking with 5.1 AAC for now )
-Download and install A52 codec for Quicktime ( reads AC3 streams in quicktime ) Note: DOESN'T PASS the AC3 stream OUT of quicktime. That is something Apple has to do to the OS.
http://trac.cod3r.com/a52codec/
-Download and install MPEG streamclip - http://www.squared5.com/svideo/mpeg-streamclip-mac.html
You also need to have Quicktime PRO -
- Export from EyeTV - "MPEG PROGRAM STREAM" - Then edit the file with MPEG Streamclip. Better at getting the edits correct, and editing the AC3 audio. Re-save the new edited file.
VIDEO ONLY FIRST -
After editing - export from streamclip - Quicktime movie - x264 / restrict bitrate kbps ( See below ) / 720p VIDEO ONLY - NO SOUND // NOTE - never change the frame rate.
Source material =1080i MPEG2 Stream@30 fps - restrict bitrate = 3000 kbps
Source material = 720p MPEG2 Stream@59.94 - restrict bitrate = 1800 kbps
Create a 5.1 AAC into the quicktime file.
- Demux AC3 stream from file ( Using Streamclip )
- Open the AC3 stream into Quicktime - Export Quicktime .mov file - 5.1 AAC file -
- Open exported x264 .mov video file - Open AAC .mov file - BOTH IN QUICKTIME
- Select all in the AAC file and COPY it.
- Go the x264 video file in Quicktime, make sure the playhead is at the beginning of the file and do a "add to movie". MAKE SURE you do a "Save As" - file - DONE!
post #3 of 4
These settings are working better, but it's still letterboxing the content. It's driving me nuts. Maybe it's the exporting as 480p widescreen that's the problem. I'll try the 720 HD setting and see if it changes things.
post #4 of 4
Andrew:
Have you tried exporting to a plain old DVD via Toast?
Although it will export a standard definiton picture, it's fast, and retains the digital sound.
  Back to Forum: HTPC - Mac Chat
