AVS › AVS Forum › Video Components › Home Theater Computers › HTPC - Linux Chat › FFdshow Linux port issues
post #1 of 5
What would it take to port ffdshow to Linux for use on major distros like Ubuntu, Knoppix, or Freespire?
Is there a DirectShow-equivalent API layer in the X-Windows display system? Could a Linux ffdshow be made in the style of XvMC, or does another video API layer need to be used or developed?
If an OS video API/driver could not be developed easily or within a reasonable timeframe, what about an ffdShow plugin for the most popular video media players like Mplayer, Xine or ???.
If a plug-in framework couldn't be used for current media players, what about forking one of these media players and adding ffdshow subroutines as video processing options in the player?
Just brainstorming...
post #2 of 5
I do believe that FFDShow is just the FFMPEG library with hooks to Directshow on Windows. The library should be available to any player and I think MPlayer, VLC and Xine can use it's stuff now at least to some extent.
post #3 of 5
So far all the major media players have built their own engines. There are frameworks out there (mlt, gstreamer), but for some reason thay remain unpopular. KDE4 will include a new API that will be able to use xine or gstreamer as its backend.
Mplayer has a chained plugin system, but doesn't have as many plugins as ffdshow. Xine also has a chained plugin system, but is less featureful than mplayer. Nobody has the UI right (to the point of being tragically comical).
Troubleshooter is right though, ffdshow is actually a [i[Windows[/i] port of a Linux library. Most of the Linux players use ffmpeg for decoding and encoding some types of audio and video.
post #4 of 5
So it sounds like Linux media players that use ffmpeg simply need to expose the ffdshow-like video processing controls/options in a GUI config panel, unless all the video post processing options like noise reduction, resize algorithms, sharpen algorithms, and others were added on top of the ffmpeg library?
post #5 of 5
The FFmpeg project includes the libraries: libpostproc and libswscale. Whether ffdshow is using those exclusively, not using them, or has augmented them is an entirely different question. I have no idea -- ffdshow info isn't particularly easy to ascertain. Then again, what are the Linux media players using? FFmpeg's libraries? Their own? Augmentations of FFmpeg's libraries? I would guess exclusively FFmpeg's (especially in the case of MPlayer...Xine may have implemented some of their own).
MPlayer has a myriad of command line options (which, of course, can also be added to the config file), but that gets to the point: the "need to expose the ffdshow-like video processing controls/options in a GUI config panel"
Its likely that this has been discussed on the various mail lists (FFmpeg's, MPlayer's, Xine's, VLC's, ffdshow's, ...) before, so perhaps a more definitive answer can be provided from a search from them.
Alternatively, I suppose one could look at the code.
  Back to Forum: HTPC - Linux Chat
