Originally Posted by
krasmuzik
The point of their patent is to use edge rather than bandpass filters. This means their filter stack does not optically make a CIE XYZ response - rather they take the response of the edge filters - and do some DSP math to come up with the XYZ response. XYZ response is the total energy - the integral under those curves
So according to that diagram - filter 7 is good for >640nm, filter 6 is good for >600nm - take their integral difference and you know the energy in band 600-640 (roughly as it depends on each diode and filter performance) Above 640nm there is some X, little Y and no Z response. This mean deep red/IR band is digitally filtered rather than optically - thus the external filter which optically converts all of the edge filters into essentially passband filters to avoid the digital noise.
ok, thanks for that explanation, this makes alot of sense now. Simulating bandpass filters using edge filters allows you to optimize rising AND falling slopes of the X,Y,Z functions.
krasmuzik
They key in all this is do you get the same integral response when you apply the resultant filters - and that depends on the calibration tables in the Spyder - which Derek has investigated and found many samples all had the same tables. It is unlikely that individual diodes and filters have the same response - so the error lies in the poor factory preset - it needs calibrated to be accurate. They are going to charge way more for the Platinum sensor even though it is the same hardware - you pay for that calibration.
That is precisely my point, you
don't get the "same integral response" unless the source function (LCD, plasma, crt, whatever) is identical (spectrally) as what was used to calibrate. It doesn't matter how good the s2 calibration is if what you are calibrating has signifcantly different spectral features. For example, you could not use an S2 to calibrate a tungsten lamp unless they provide calibration coefficients obtained with that source.
