Thanks for the reply.
I just skimmed through the poorly written manual. I could be wrong, but am I to understand that it won't decode DD or DTS without 3rd party software decoders? It has limited inputs, although it's cheap enough compared to a pre-pro. I think the non-shared IRQ requirement is a bit much in this day and age. I haven't built a PC in a while, but my P4PE doesn't have one slot where the IRQs aren't shared, I don't think. Am I also to understand that the bass management is for LFE only? I wasn't too clear on how the bass management works. But bass exists in music not just LFE.
If it sounds good, the cost is a definite advantage. However, I must consider the convenience of a pre-pro. I'll check to see if some of the events for volume are exposed in girder. Perhaps there's some plug-in. But it appears my mindset is heading in the pre-pro direction.
