Vishal!! Thanks for the input! Yeah, I am not used to using a center channel (my last four (!) systems did not have them and I didn't miss it ..... have you HEARD a Ref AV Cntr. with 3.1's, yet? If not please share your honest assessment when you get it. I will probably go the same way that you have and get the dedicated center, do without, or wait until I have room for another single Ref 3.1 in the middle ... I don't have room yet. I plan to upgrade the Due's in the rear probably with two other Ref 3.1's (I told you guys I was anal about this stuff), if I decide to keep the Gallos, which I'll set-up tonight.
My system is:
-2 Ref 3.1's / front.
-2 Due's / back.
-Martin Logan Dynamo sub (to fill in from the Ref 3.1's, rather than go the S.A. route) - hasn't been heard yet
-Denon 3806 rec., as a preamp, out to ....
-4 Marantz mono amps which will pump out 200 watts / channel in 8 ohms, and something like 300 / 4 ohms
!!! - haven't rec. all of them yet (just 1/4) so for the time being, I'll just use the power from my reciever .... *sigh* ...
-Denon 3910 Universal DVD player using direct dig. to the 3806 ... SUPER for sacd / dvd-Audio ..... sorry no vinyl for this cat .....
-Pioneer 300 disc multi-changer for the cd backcatalogue (for non-dedicated listening)
-Monster Power Conditioner HTS 3600 mk 2
-Stock bulk wiring salvaged from my recording studio ... 12 gage ...
