AVS › AVS Forum › Audio › Speakers › Official Anthony Gallo Owners Thread
Official Anthony Gallo Owners Thread - Page 24
post #691 of 2758
Yes, and I saw a review in a magazine of the TR-1 and they were awestruck over its performance so it isn't easy to know.
post #692 of 2758
OMG, I contacted the nearest Gallo-dealer to inquire about Gallo A'divas and he said they didn't have any for demo, but they did have a pair of demo 3.1s going for ca 50% discount... A bit above my budget, but what is a budget, really?
post #693 of 2758
What are you doing on line?!?!?!
Get down there quick!!!
post #694 of 2758
"Ok, but isn't distortion good..."
No. And if you disagree, then, like Mr. Bostonbean, I'm afraid I can't really help you.
Here are the measurements for the TR-1:
http://www.hometheatershack.com/foru...-tr-1-new.html
These are very poor measured results.
Here are the results for your SVS Sub:
http://www.hometheatershack.com/foru...-db12-2-a.html
These are very respectable results.
If you want a higher crossover point than consider:
http://www.hometheatershack.com/foru...-2nd-unit.html
I can't recommend the TR-1 based on it's measured results. Like I said, I'd give your SVS a try, first. If it doesn't provide enough distortion and compression for your liking then get the Gallo sub and enjoy. Can't argue that the Gallo kit looks much better than the SVS fare. That is a consideration/trade-off only you can make.
post #695 of 2758
I got the offer via mail, I have mailed them, and called twice.
The price is just over what 3 A'divas retail for here...
And they also had the SA-amp going demo-used at 50% discount. Is it any good?
post #696 of 2758
Just got the 3.1s and SA-amp-deal settled. They are mint cond. and stainless/black. A bit above my budget so say the least, but the 3.1s should be as "good as any".
Is an Onyko 875 good enough to drive the 3.1s together with the SA-amp, or should I have something more powerful.
post #697 of 2758
Your early post wasn't clear, do you still have the other set of 3.1s you mentioned earlier?
If so are you going to run them in a 4.0 set-up? That would offer quite impressive sound!
What is the Onkyo's rated power out-put?
post #698 of 2758
You will probably drive the SA off of your pre-outs so power should not be a problem.
post #699 of 2758
No, I had some difficulties in my new room and sold them. Dumbest thing I ever did. Luckily this offer came up.
I am a music mostly guy and the Ref Center is a bit expensive. Would a A'diva be way to small for center duty? Better with 4.0?
Jan
post #700 of 2758
Ok, so 875 driving the usual speaker and the SA as "extra" bass is good enough to get them rocking?
How much bass will I get in a 13.5 x 14.5 room? Enough? (Very subjective, I know)
post #701 of 2758
Well, you already have a sub so for movies you will be fine. My setup is for 2 channel music and I can make the bass overpowering if I choose. I just use it to boost the bass at the point it begins to roll off. You will have to play with it in your room.
post #702 of 2758
Congrats on the Ref 3.1 purchase - you'll have a much better system now!
The 875 is about as powerful as HT Receivers get so it should be fine. That said, you could always get a nice strong stereo amp to drive the Refs... now what was your budget again?
post #703 of 2758
The Onkyo should be fine. My room is 17x14 and opens into the dining area. I initially drove my setup with a 140 wpc Pioneer receiver. I just happened to come upon a deal on a 200 wpc Icepower amp.
post #704 of 2758
My setup is also primarily for 2 channel, but I do love an occational movie and concert-dvd/BD. I will probably be back later this week with the need of aid in setting the thing up.
I think there is enough power, and the 875 is a really good amp when it comes to resolution and clarity so I think there are other parametres than the electronics that should be taken care off first.
I have a SVS-tube sub in the room already, but I may stop using it if the 3.1s play loud enough.
post #705 of 2758
Jan
I'm very happy with my 4.0 set up, and I watch a bunch of movies...
Gallo Reference 3.1 front (was Reference II until a couple of weeks ago), Gallo Solo vI for the surrounds.
post #706 of 2758
Ok, I am really excited that I could get the 3.1s with subamp on my "budget".
The dealer lies right where I work so I may even get them tomorrow
Any opinions on A'diva Ti as center? Not worthwhile?
post #707 of 2758
I've never owned a center channel speaker. I've always owned musical front speakers with great imaging and clear mid-range. I have never missed having a center channel. As with all system, build it one step at a time. You can always add a center channel later, if you can't get solid voice positioning in your room.
Since I own the Ref 3.1s and know how they image, I'd be very surprised if you need a center channel. But every room is different. That's why I'd wait and see.
Devil's advocate: it can't hurt to have a center channel speaker.
Counter: it will unnecessarily hurt your bank account.
Your call, Ace.
post #708 of 2758
I understand, and agree.
I am even considering going for å clean 2 channel-setup, but I don't know what 2 channel integrated that can swing the Gallos for the price the Onkyo retails for - the sound out of the Onkyo is so good it rivals many 2 ch products costing more than it does....
post #709 of 2758
While great for the money/size, the A'diva Ti is significantly inferior to the 3.1s and you will likely be unhappy with the timberal match.
post #710 of 2758
Not worthwhile, unless using the same as your left/right speakers. A perfect center match would be the Ref A/V. Second choice, The new Strada.
post #711 of 2758
I demoed the reference center and could barely tell the difference from having no center at all. I had to keep walking up and checking to see if it was even on.
post #712 of 2758
I see.
I am collecting the 3.1s on my way home tomorrow, and boy am I excited.
If anyone here have tried some 2 channel integrated amps on 3.1s that play really well I would appreciate some hint and tips Considering moving to 2 channel setup.
post #713 of 2758
Just to follow up. The 3.1s are in house and are now playing - like hearing the Angels singing. Good Lord, these speakers are GOOD! The SA also seems to fill in the bottom nicely.
I am however considering getting 2 x TR-1s to place one beside each front for the best bass response.
post #714 of 2758
I think you're likely to do more harm than good by adding the additional woofers. It's difficult to properly integrate additional sub-woofers. Do you really feel a need for more bass? I'm running my 3.1s without the SA and don't feel I'm really missing anything...
I'll put Toccata and Fugue on tonight just to double check
post #715 of 2758
Take some time, play with the positioning and crossover points on the SA. I can't imagine you need subs for music and given that your 3.1's are demos, they should be broken in.
post #716 of 2758
"I am however considering getting 2 x TR-1s to place one beside each front for the best bass response."
So you/ve got the Ref 3.1s with 10" woofers, plus the Sub Amp to drive the dual voice coils for response down to 22Hz, plus a SVS 12" SW, and you want to buy 2 more TR-1s?!
post #717 of 2758
"I'll put Toccata and Fugue on tonight just to double check"
Me too - I bought a SACD of Bach Fugues They remind me of my High School band where we used to warm up on fugues. Methodical, pedantic, and relaxing... love 'em even w/o a subwoofer
post #718 of 2758
No, I am considering selling the SVS and getting 2 TR-1s instead.
post #719 of 2758
Did you get the SA as part of the deal?
post #720 of 2758
Yep.
  Back to Forum: Speakers
