Need some advice.
I'd like a screen that's:
This is for a pretty cheap LCD projector. Is this possible? If it's not, the only thing that's not flexible is the size.
DIY is an option. I can give up on the pulldown. I can sacrifice some audio performance. There are just so many options I don't know where to start - what would you do?
- pulldown
- acoustically transparent
- 10' width / 12.5' diagonal (4:3)
- under $1000
