I did this and it seems to fixed my probems. Some of these insructions are wrong. I think some of them are for vista. It took me about a hour to do. it was kind of stressful but i got the drive backed up.
TBShd is now playing fine.
I should of just bought a 4 tuner tivo and have a lot less problems.
a. Uninstall PlayReady from the 'Programs and Features'
b. Enable the explorer to show hidden files and folders. To do this go to Windows Explorer > Tools > Folder Options > View tab > Show hidden files, folders and drivers
c. Go to %ProgramData%\\Microsoft\\ and delete the PlayReady folder.
d. Go to %ProgramData%\\Microsoft\\ and delete the DRM folder.
e. Go to %ProgramData%\\Microsoft\\Windows\\DRM and delete all files and folders underneath (don't delete the DRM directory itself)
f. Open the registry with elevated privileges. To do so, click Start, click All Programs, click Accessories, right-click Command Prompt and then point to Run as administrator. In the command prompt that opens, type regedit.exe.
g. Go to HKLM\\Software\\Microsoft and delete the DRM key.
h. Run the ResetDRM tool. See
http://www.cetoncorp.com/support/ind...ayready-issues
i. Restart the computer.
j. Run Windows Media Center setup again
k. Run the PlayReady install from inside Media Center
Originally Posted by
tootal2
tbshd 780 is set to
CGMS-A: "ONE COPY" (0x002) copy management system analog
I hope you can fix this.
