Originally Posted by chuckparr
Have considered. Local dealer recommends a ten foot mast ((I'm north of Alton) plus would need a HD tuner. Satellite seems like a one-stop solution instead of switching antenna/cable depending on what we are watching. Plus in long run it seems either satellite choice will have more HD choices than Charter. After a year they added three crappy stretched HD channels.
I did a quick check of Alton's zip code in http://antennaweb.org/aw/welcome.aspx and you would have no problem pulling in the HD channels from St. Louis. CBS is only 27 miles away. Why not have the OTA antenna and satellite? That is what I have with Dish. I even have the OTA mounted in the attic. The VIP722 HD DVR with Dish can record three tuners at the same time using the OTA antenna. The OTA picture looks just as good as satellite. With the OTA you would have backup to satellite if you have loss of signal from thunderstorms. The 722 works bunches better than Charter's MOXI and the Motorola 3416 DVR.
