AVS › AVS Forum › Video Components › Home Theater Computers › HTPC - Linux Chat › MythDVD -- Can't Import DVD
post #1 of 3
Ok,
I'm unable to import a DVD. I go to import DVD, it shows the info on the DVD, I hit '0' to start, it says "Nothing to do."
I found /var/lib/mythdvd/temp/mtd.log, and it has this error:
21:31:06: bad destination directory in job request: job dvd 5 1 -1 0 -1 /share/Movies/dvd/VAN_WILDER_UNRATED_D1
And, of course, /share/Movies/dvd doesn't exist.
Now, I suppose I could create it, but, I'd rather learn how to change it, so I can point to a different directory.
Can anyone tell me where to change this setting?
AdvThanksance,
-Mark
post #2 of 3
I don't have an older .18 box with MythDVD any more so I don't know. I do know that the current plugin (mytharchive) does have a setup screen to put that path in under media options I believe. Alternatively, you can make a symlink from the directory you want to actually put the stuff to that path it's looking for. The data will still end up in the right place.
post #3 of 3
Well, I found it. I kept looking under DVD rip options, but, it's not there. It's under Utilities/Setup->Setup->Media Settings->Video Settings->General Settings
-Mark
  Back to Forum: HTPC - Linux Chat
