AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Are there more placement options....
post #1 of 2
Are there more placement options for a sealed sub vs. a ported sub?
post #2 of 2
Depends on where the port is placed. If you have a front firing sub with a rear port you will need some space between the rear of the sub and the wall. A sealed sub would not have the same restriction.
