AVS › AVS Forum › Video Components › Home Theater Computers › HTPC - Mac Chat › Front Row not cutting it
post #1 of 4
I have an Intel Mac Mini I have connected to my Sammy 4095D. It looks great, but Front Row just isn't cutting it for me anymore.
I currently have no TV service, and get the majority of my media from the iTunes store. I do also have an extensive DVD library on my server as well as AVI files.
I am looking for a front end application to bring everything together. I thought MediaCentral might be the solution, but it cannot play TV shows downloaded from the iTunes store.
Any advice on what software packages I should try?
post #2 of 4
If one of your requirements is playing TV Shows with Fairplay DRM, then I think you are stuck with Front Row.
post #3 of 4
One possibility is http://mysite.verizon.net/resohjb1/Projects.html, a free AppleScript to allow FrontRow to access video_ts folders. I think there used to be a thread here, but it looks like it may have been archived.
There are a number of threads here regarding various FrontRow replacements/enhancements, one or more of them may be helpful.
EDIT: Here's the AVS thread that I thought I remembered:
http://www.avsforum.com/avs-vb/showthread.php?t=714917
post #4 of 4
I haven't used it, but isn't something like Remote Buddy a Front Row extender? It will allow you to use Front Row as before, but will do all sorts of additional things for you (such as play your DVD Library).
  Back to Forum: HTPC - Mac Chat
