AVS › AVS Forum › Other Areas of Interest › Car Audio, Video, and Nav › Upgrading Factory system - Any suggestions
post #1 of 3
Hello everyone. I'm hoping I can find some good advice from this forum.
I'm looking to upgrade my factory 2001 Escape head-unit with an aftermarket system. One of the primary things I am looking for is ipod connectivity through the unit. From looking at other sites there are three brands that I am looking at:
Alpine, Pioneer, and Panasonic.
Has anyone had any good experiances with these brands and which model are being used? I'm looking for something under $200 for the unit alone.
Also, I heard that the transfer rate from the ipod to a Alpine deck was faster than the other two. Any comments on this?
post #2 of 3
I like eclipse, awesome sq, but go to a shop, b/c I have also had good experiences with pioneer and alpine, I would get an eclipse, but you should get the one with the features you need...
post #3 of 3
I am not sure if you are still going to check this thread but I will answer anyway.
I would highly suggest going with Alpine. Eclipse makes really good head units too but tend to be more expensive. For $200, you will get a much better value from Alpine.
  Back to Forum: Car Audio, Video, and Nav
