Originally Posted by
sut
here u go
Sharp XV-100 DLP Home Cinema Projector ( XV100 XV 100 ) SHAXV100
Price
£999.00
Buy Now Pay Later
or from £26.55 /month Credit Example (Over 48 months)
New Home Theatre Projector Provides High-Contrast Pictures and Long-Lasting High-Quality Performance from Cutting-Edge DLP Technology
# DLP Technology Advantages: 2,500:1 High Contrast Ratio and Film-like Seamless Image
# DTV⁄HDTV (50⁄60Hz), 1080I, 1035I, 720P, 576I, 576P, 540P, 480I, 480P with 4:3 and 16:9 aspect ratios and DVD compatible
# 1,000 ANSI Lumen High Brightness
# Low Fan Noise: 30 dB (Low Power Mode), 33 dB (Standard Mode)
# Superb dust resistance achieved with DLP Sealed Optical System
# Condenser Lens Optical System provides higher image uniformity and contrast without ghosting
# High Speed Colour Wheel prevents rainbow effects (NTSC: 5X, PAL: 6X)
# Advanced Picture Mode quickly recalls the appropriate settings to match the application purposes
# Up to SXGA+ (1,400 Dots x 1,050 Lines) and Mac 21" (1,152 Dots x 870 Lines) High-Resolution Images Compatible in Advanced Intelligent Compression System
# True WVGA (854 Dots x 480 Lines) High-Resolution Images
# Freeze⁄AV Mute
# IP Conversion by TrueVisionTM Image Processing
if u need anymore if just google the make and model
