AVS › AVS Forum › Video Components › Home Theater Computers › HTPC - Mac Chat › AppleTV - Converting my files into compatible format
post #1 of 7
Hello,
I am thinking about purchasing the AppleTV, even though I won't be able to purchase movies for a while (in Canada). My goal is to stream movies from my computer, and my movies are in these formats:
1) DVD rips (.iso, .img, video_ts)
2) Xvid/Divx/Mkv/Mpeg/
How do I convert these into the H.264 format compatible with AppleTV ?
What software do I use? I am using Windows XP.
Francois
post #2 of 7
You can use Nero 7, handbrake, X.264 and theres probably more.
You might want to wait and see what are the exact limits of the appletv.
post #3 of 7
I think anything that can create iPod video. I think the formats are compatible.
Also here are 7 others:
http://www.versiontracker.com/php/se...indows&x=0&y=0
I'd also know that mpeg streamclip and avidemux have windows versions. Both are powerful.
--sdm.
post #4 of 7
Handbrake has been forked so check out MediaFork. It's an updated, and hopefully, properly maintained version of Handbrake.
post #5 of 7
You might want to wait a bit and see if the apple tv will support mulit-channel aac.
No word on this yet. It makes logical sense (why else have a optical out) but the ipod is only 2 channel ....
post #6 of 7
Can someone tell me if the AppleTV will read .mp4's encoded using Handbrake's PS3 setting?
Why you ask, because I have a PS3 and much of my library is already encoded to the PS3 format, but I've decided I like the AppleTV interface better. Thx in advance.
post #7 of 7
One option would be to install XBMC on it, after that it would play almost anything you throw at it. Within the limits of hardware of course.
  Back to Forum: HTPC - Mac Chat
