AVS › AVS Forum › Video Components › Video Processors › can I use HDMI to output audio in C2 ?
post #1 of 7
Hi all,
I'm new here. I have a C2 and all my video and audio are connected to the C2 through HDMI. A Coaxial Cable from the C2 to my Receiver for audio transmit.
Since I'm cannot get LPCM 5.1 from the Coaxial Output to my receiver ( I heard that Coaxial doesn't support LPCM 5.1).
My question is, can I use the second HDMI OUT in C2 for only audio ?
thanks
Kith
post #2 of 7
It works fine.
It send the picture info as well, but that shouldn't matter.
post #3 of 7
would you mind tell me how you setup hdmi for audio output ?
I have hdmi output port 1 sending video out to my plasma. Now I connect hdmi output port 2 to my amp, I cannot get any audio.
thanks
Kith
post #4 of 7
hmm - from memory it should just work.
afaik all output ports are active simultaneously. Have you told output 2 to get the input from the correct connection?
I'm away from my C2 at the moment so I can't check.
post #5 of 7
finally I make it work, but obviously not the most elegant way.
Blu-ray player > Denon Receiver > C2 > Plasma
ideally, it should be ,
Blu-ray player > C2 >
a > HDMI audio out to Denon Receiver
b > HDMI video out to plasma
but anyway, it work at the moment, I will try and do more research.
thanks and please let me know if there are a better way to do it.
Kith
post #6 of 7
You may need to config the HDMI Output in "Auto" mode for the embedded audio, instead of the default "Force DVI" mode. Check from the front panel, Output->Port Config->HDMI1/2->DVI mode->Auto.
regards,
Li On
www.pixelmagicsystems.com
post #7 of 7
regards,
Li On
Thanks Li On, I managed to get HDMI audio through the HDMI 2 output port. Yes, by using your suggestion.
But, LPCM Uncompress 5.1 still doesn't work, my receiver still getting 2 channel stereo instead of Multichannel surround (which I get by using my method). So, now I need to go back to what I did until something get resolved.
Hope you guys can test it (the movie I tested was Kung Fu Hustle).
Kith
  Back to Forum: Video Processors
