I recently added a Bryston 9BSST to my family room entertainment system and relegated a 84TXSi to 'pre/pro' duties. I cut the end off and stripped 1/4" wire off of a mono miniplug and connected it to the 12v trigger switch on the Bryston, plugging the other end into the 12 v trigger out on the 84. I went into the 84's setup menu and enabled the 12v trigger option to "Main" for all inputs. However, regardless of what I do, the 84 displays "12v Trigger Error" for all inputs even after cycling the receiver and Bryston (manually) on and off several times. I have the Bryston's input set for a 4 second delay to prevent any surges.
I have an Anthem Statement D2 pre/pro in front of a Bryston 6BSST and a pair of 4BSST's down in my HT, setup the same way and it works flawlessly.
Any ideas?
Any ideas?
