AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › I Got A Request
I Got A Request
post #1 of 10
Alright guys I am looking for an LCD HDTV Size 20-32 Inches, with HDMI and below 700 bucks but also if you gusyw ould recommend a TV i would look into it
post #2 of 10
Jeez, can I get any replies!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
post #3 of 10
Not enough information. If price is the only issue, just go buy one.
viewing distance, installation room (light, windows, dark), types of
input (standard def, HD, DVD, OTA), are all things needed to help
you. Again, if price is your only criteria, then just go get the lowest
price one and you don't need help.
post #4 of 10
Well i think i want it to be HD-Ready and it is for a small bedroom for a teenager (12 years old) and has a PS3 and sits right in front of the TV most of the time while playing but sometimes lays down on the bed wich is probably 5 feet away from the TV and i dont want a DVD payer in it(PS3 is the DVD player and Blu-Ray Player
post #5 of 10
My opinion:
720p set, local store with good return policy (in case of issues), largest
set in your budget (12 year old should be THRILLED with whatever you
get to work with the PS3)
post #6 of 10
Originally Posted by flatpanel View Post
My opinion:
What he said, and go for size over the best brand name. A 12 year old will be more impressed with size than the best technical PQ.
post #7 of 10
How many more threads are you going to start with this request?
Heres the other thread you started
http://www.avsforum.com/avs-vb/showthread.php?t=807062
Did you not like the answers given there and decided another useless thread would help?
post #8 of 10
This
post #9 of 10
alright well ive been looking into the VIZIOs and they look great and cheap but you see would a 20" LCD HDTV w/HDMI look good with the PS3 or save up about 300 more bucks to get a 32" Vizio LCD HDTV w/HDMI
post #10 of 10
