Cork Flooring?
post #1 of 12
Anybody have an opinion on cork flooring. I have hear many of the positives such as: Thermal barrior from basement floor, environmentally friendly, moisture resistant. Does anybody know the sound implications? What is the best flooring for a HT/Game Room?
post #2 of 12
From what I hear, it is very sound absorbent.
post #3 of 12
Maybe not.
The NRC of 3/4" cork is .1 to15.
The NRC of carpet over foam is as high as .55.
See http://www.nrcratings.com/nrc.html
If you are more concerned about transmission through the floor this site has some numbers for the STC of a cork product). http://www.quietcork.com/testing_results.html
post #4 of 12
Correct. A cork floor is a poor sound absorber. It is good a reducing impact (footstep) noise, but so is carpet.
- Terry
post #5 of 12
Sorry, I should have researched before posted...
post #6 of 12
No need for an apology! You probably did hear that cork floors were very sound absorbent. This is one of many acoustical fallacies spread by contractors and even manufacturers.
- Terry
post #7 of 12
So if cork is not as good for an HT, what should one use in construction of a basement ht when carpet is out of the question?
post #8 of 12
Memory foam!LOL
post #9 of 12
An absortive ceiling can compensate for a reflective floor. Quality acoustical ceiling tiles (fiberglass construction, such as Armstrong Optima) can be fastened directly to a drywall ceiling. This does not to compromise sound isolation, as might a suspended ceiling.
Terry
post #10 of 12
Definitely check on the manufacturer's signoff to use in a basement. I know that when we installed cork planks in our kitchen, there were some large warranty invalidation terms that included use below grade.
By the way, the cork floors are great: they look and feel delightful.
post #11 of 12
it might smell like wine
post #12 of 12
Just something to keep in mind too: cork flooring will fade over time if exposed to the path of direct sunlight. There are multiple windows in my basement (south facing) and this would be an issue if I used cork. Just and FYI. It is a good insulator from cold though :-)
