Lens cleaning?
post #1 of 3
I think I need to clean my lens off on my projector. Is there a recommended way to do it? On a former projector I had I tried to clean it and wound up with smudges that never seemed to go away.
post #2 of 3
You clean a projector lens the same way you clean any other fine optics (camera lens, microscope lens, etc.)
First use a blower or a clean source of compressed air to blow any loose dirt and dust off the lens.
Then use lens tissue or a clean microfiber cloth slightly moistened with a good lens cleaning fluid (never apply fluid directly to the lens) and starting in the center of the lens use a rotary motion and work your way out.
Remember, more lenses have been ruined by improper cleaning than by not cleaning at all.
post #3 of 3
Originally Posted by Jerry Gardner View Post
Remember, a dirty lens is better than an improperly cleaned one.
Yeah, I found that out the hard way before. Thanx.
